Mercs not remembering my saved games: Dosbox
FinalFantasyFanatic
Post by FinalFantasyFanatic »
I'm running Windows Seven and using the Mercs: Retail 1.05 95/DOS version of Mercs which I installed in Dosbox after making an image of the disk via clone cd. After the intial installation, it runs perfectly but it I want to run the game later it doesn't remember my saved games, nor does it have any sound (it did have sound after installation), it also won't play movies nor am I able to actually play the game (it throws up a heap of errors).
Re: Mercs not remembering my saved games: Dosbox
Either create a batch file that will mount the CD image everytime you launch the game, or use MechVM to set it all up for you.
FinalFantasyFanatic
I already tried MechVM and it didn't work for me even though it did install the game, I couldn't get it to play. So I installed it into Dosbox, but it only runs properly after the initial installation (how do I create a batch file to mount the cd)?
The batch file your talking about isn't the same one as the one in the dosbox config file is it? Because I've already set it to mount the image every time DosBox is started.
[autoexec]
# Lines in this section will be run at startup.
mount C C:\DOSBox
imgmount E C:\DOSBoxGames\MechWarrior2\Merc.cue -t iso
I need the file install-report.txt from where MechVM installed the game to diagnose the problem.
FinalFantasyFanatic
http://www.mediafire.com/file/mzjndjnyy ... report.txt
MechVM-2009-11-29
Windows 4.0
Source: F:\
Target: E:\Programs\MechVM-win32-2009-11-29\games\mw2-mercs-dos
File listing for F:\
ADSET.DLL 19968
AUTORUN.INF 275
AVI <dir>
BUTTON.WAV 59436
CFGS <dir>
DENIED.WAV 75820
DIRECTX <dir>
DLL <dir>
DOS <dir>
DOSHELP.GID 8628
DOSHELP.HLP 45056
DOSNET.GID 8628
DOSNET.HLP 32768
DSET.EXE 76288
DSETUP.DLL 20992
DSETUP6E.DLL 34400
DSETUP6J.DLL 34288
DSETUPE.DLL 41984
DSETUPJ.DLL 41984
EREG.BMP 57078
EXIT.WAV 77868
GIDDI <dir>
GIDDIWIN <dir>
GPREV.WAV 28268
HELP.GID 8628
HELP.HLP 329373
INSTALL.WAV 71724
INTERNET.TXT 25998
KEATING <dir>
LAUNCH <dir>
MEK <dir>
MERCS <dir>
MIDIDLL.DLL 20480
MISSIONS <dir>
MORE.WAV 45100
OLD_MERC.DRV 264
PRODUCT.INI 204
README.TXT 44835
REGISTER.EXE 250880
RMG <dir>
SETUP.BMP 57078
SETUP.EXE 47104
SETUP.INS 114514
SETUP.PKG 10899
SMK <dir>
SND <dir>
SP16 <dir>
SP256 <dir>
SPLASH.EXE 52736
SPLASH.WAV 28268
TOOLS <dir>
UNINST.EXE 261632
UNINST.WAV 65580
VENDOR.GID 8628
VENDOR.HLP 47104
VFX <dir>
VIDDLL.DLL 78336
WAIL32.DLL 7
_INST32I.EX_ 296021
_ISDEL.EXE 7680
_ISRES.DLL 88576
_SETUP.DLL 9728
_SETUP.LIB 2001907
File listing for F:\AVI
. <dir>
.. <dir>
HYPER.AVI 12767084
I76.AVI 9783450
TIME.AVI 26254026
File listing for F:\CFGS
. <dir>
.. <dir>
MW2.ADV 2318
MW2.B50 2418
MW2.M50 4938
MW2.PHX 1674
File listing for F:\DIRECTX
. <dir>
.. <dir>
D3D.INF 1097
D3DHALF.DLL 107008
D3DIM.DLL 68096
D3DRAMPF.DLL 110080
D3DRG16F.DLL 217088
D3DRG24F.DLL 156672
D3DRG32F.DLL 154624
D3DRG8F.DLL 217088
D3DRGBF.DLL 110080
D3DRM.DLL 282112
D3DRM16F.DLL 470528
D3DRM24F.DLL 137216
D3DRM32F.DLL 134656
D3DRM8F.DLL 469504
D3DXOF.DLL 72704
DDHELP.EXE 31744
DDRAW.DLL 159744
DDRAW.INF 820
DDRAW16.DLL 22992
DIRECTX.INF 2311
DPLAY.DLL 39936
DPLAY.INF 1549
DPSERIAL.DLL 41472
DPWSOCK.DLL 24064
DRIVERS <dir>
DSOUND.DLL 86016
DSOUND.INF 435
DSOUND.VXD 17087
DXSETUP.EXE 29184
LICENSE.TXT 1151
File listing for F:\DIRECTX\DRIVERS
. <dir>
.. <dir>
AUDIO <dir>
DISPLAY <dir>
File listing for F:\DIRECTX\DRIVERS\AUDIO
. <dir>
.. <dir>
BIN <dir>
MSDSOUND <dir>
MSDSOUND.INF 64285
File listing for F:\DIRECTX\DRIVERS\AUDIO\BIN
. <dir>
.. <dir>
AZT16.VXD 26770
AZT16C.DRV 42080
AZT16W.DRV 43664
CDPLAYER.CNT 643
CDPLAYER.EXE 88064
CDPLAYER.HLP 20579
CSPMAN.DLL 17776
ES1488.DRV 43936
ES1488.VXD 20116
ES1688.DRV 50128
ES1688.VXD 25236
ES488.DRV 36976
ES488.VXD 19603
ES688.DRV 47008
ES688.VXD 22675
ESSFM.DRV 17920
ESSMPORT.DRV 9904
ESSMPU.DRV 8240
FINDMVI.DLL 5728
IMAADP32.ACM 18944
MMMIXER.DLL 5152
MPLAYER.CNT 1042
MPLAYER.EXE 147968
MPLAYER.HLP 26940
MSADP32.ACM 17920
MSG711.ACM 10240
MSGSM32.ACM 25088
MSJSTICK.DRV 7744
MSMPU401.DRV 8704
MSOPL.DRV 17952
MSSBLST.DRV 40848
MSSBLST.VXD 21142
MSSNDSYS.DRV 39728
MSSNDSYS.VXD 29932
MVI514MX.DRV 38432
MVIWAVE.DRV 19760
MVMIXER.DRV 59568
MVPAS.VXD 8898
MVPROAUD.DRV 26128
PA3DMXD.DRV 53200
SB16.VXD 70235
SB16SND.DRV 46000
SBAWE.VXD 42226
SBAWE32.DRV 23216
SBFM.DRV 4128
SNDREC32.EXE 105472
SNDVOL32.CNT 392
SNDVOL32.EXE 54784
SNDVOL32.HLP 11120
SOUNDREC.CNT 1023
SOUNDREC.HLP 24895
SYNTHGM.SBK 34832
TMV1.MPD 12048
TSD32.DLL 17408
TSSOFT32.ACM 8704
VJOYD.VXD 20590
VMVID.VXD 18586
VPASD.VXD 24162
WFM0200.ACV 13456
WFM0200A.CSP 2238
WFM0201.ACV 5184
WFM0201A.CSP 6776
WFM0202.ACV 9056
WFM0202A.CSP 9004
WFM0203.ACV 9056
WFM0203A.CSP 9004
File listing for F:\DIRECTX\DRIVERS\AUDIO\MSDSOUND
. <dir>
.. <dir>
ISNA.DLL 6064
File listing for F:\DIRECTX\DRIVERS\DISPLAY
. <dir>
.. <dir>
BIN <dir>
MSDDRAW <dir>
MSDDRAW.INF 39547
File listing for F:\DIRECTX\DRIVERS\DISPLAY\BIN
. <dir>
.. <dir>
5631_DIG.INI 38690
5631_HWC.INI 38120
5631_SWC.INI 38549
883D_DIG.INI 38690
883D_HWC.INI 38120
883D_SWC.INI 38549
ATI.VXD 27440
ATI3D.DLL 204288
ATIM32.DLL 11264
ATIM32.DRV 99184
ATIM64.DLL 19968
ATIM64.DRV 81104
ATIM8.DRV 129584
CDALLOC2.EXE 5040
CDD16.DLL 3808
CDD32.DLL 22528
CHIPS.DLL 9216
CHIPS.DRV 29280
CHIPS.VXD 18591
CHTDD16.DLL 3856
CHTDD32.DLL 7168
CIRRUS.DLL 23552
CIRRUS.DRV 70640
CIRRUS.VXD 17964
CIRRUSLG.DLL 9216
CIRRUSLG.DRV 41616
CIRRUSLG.VXD 15678
CIRRUSMM.DLL 39424
CIRRUSMM.DRV 72208
CMMDD16.DLL 3808
CMMDD32.DLL 25600
CP3.DLL 8128
CPX.INI 53
D3D.UC 94744
DMSICS64.VXD 17159
DMSICSS.VXD 24576
FBDD16.DLL 3824
FBDD32.DLL 7168
FRAMEBUF.DLL 8192
FRAMEBUF.DRV 22192
K2V_DIG.INI 38080
K2V_HWC.INI 38401
K2V_SWC.INI 37734
M32DD16.DLL 3808
M32DD32.DLL 10240
M64DD16.DLL 3808
M64DD32.DLL 8192
MCIMPEG.DRV 33968
MGAMIL.DLL 73728
MGAMIL.DRV 88720
MGAMIL.VXD 26954
MGAPDX64.DLL 63344
OAK.VXD 14481
REND.DRV 39504
REND32.DLL 61440
RFMDD.DLL 30236
RFMK2V.DLL 52736
RFMK2V.INI 732
S3.DLL 9216
S3.DRV 65056
S3.VXD 22255
S376DD16.DLL 3808
S376DD32.DLL 13312
S3ADE.DLL 81040
S3DD16.DLL 3808
S3DD32.DLL 8704
S3MM.DLL 14336
S3MM.DRV 76688
S3MM.VXD 23847
S3MPG.DLL 37904
S3V.DLL 477184
S3V.DRV 83920
S3V.VXD 19481
S3VDE.DLL 20112
S3_765.DRV 72912
S3_765.VXD 18580
SUPERVGA.DRV 52320
SXCIEXT.DLL 98144
TSENG.DLL 10240
TSENG.DRV 37824
TSENG.VXD 14536
TSNGDD16.DLL 3824
TSNGDD32.DLL 9216
UCMAN.DLL 23872
VB102F.COM 31095
VERITE.VXD 24576
VIDEO7.VXD 14947
WD.DLL 10752
WD.DRV 25840
WD.VXD 18333
WIN31.UC 21216
File listing for F:\DIRECTX\DRIVERS\DISPLAY\MSDDRAW
. <dir>
.. <dir>
ISS3_765.DLL 3520
S3_CP3CQ.DLL 4560
File listing for F:\DLL
. <dir>
.. <dir>
DWANGO.DLL 50070
IPX.DLL 16764
MODEM.DLL 20343
SERIAL.DLL 17267
WAT.DLL 61882
File listing for F:\DOS
. <dir>
.. <dir>
CPU.EXE 5802
DOS4GW.EXE 265420
FIXBOOT.EXE 70425
HELP.BAT 15
HELP.TXT 55876
INSTALL.EXE 276696
INSTALL.PIF 967
INWIN.EXE 5984
IVE.EXE 211414
MW2486.CFG 84
MW2PRM.CFG 704
PRODUCT.INI 204
REGISTER.EXE 162516
SETSOUND.BAT 40
SETUP.CFG 266686
SHELLMER.CFG 57380
SOUNDDRV.EXE 96305
VESACHK.EXE 9574
File listing for F:\GIDDI
. <dir>
.. <dir>
AVENGER.CPC 3872
AVENGER.DLL 8843
AVENGER.TXT 4551
CONFIG00.CPC 3872
CONFIG01.CPC 3872
CONFIG02.CPC 3872
CONFIG03.CPC 3872
CONFIG04.CPC 3872
DEFAULT.CPC 3872
FLTSTCK.CPC 3872
FLTSTCK.DLL 6831
FLTSTCK.STD 174
FLTSTICK.CPC 3872
JOYSTICK.CPC 3872
JOYSTICK.DLL 4870
JOYSTICK.STD 189
KEYBDENG.CPC 3872
KEYBOARD.CPC 3872
KEYBOARD.DLL 8207
MOUSE.CPC 3872
MOUSE.DLL 4760
MOUSE.STD 174
MSJSTICK.CPC 3872
MSJSTICK.DLL 6863
MSJSTICK.STD 178
NOVICE.CPC 3872
SIDEWIND.CPC 3872
SIDEWNDR.CPC 3872
SIDEWNDR.DLL 6072
SIDEWNDR.STD 177
SIDWINDR.CPC 0
TMASTER.CPC 3872
TMASTER.DLL 6957
TMASTER.STD 173
VFX1.CPC 3872
VFX1.DLL 3222
VIO1.CPC 3872
VIO1.DLL 4341
VIO2.CPC 3872
VIO2.DLL 4341
VPILOT.CPC 3872
VPILOT.DLL 6975
VPILOT.TXT 1120
WINGMAN.CPC 3872
WINGMAN.DLL 6941
File listing for F:\GIDDIWIN
. <dir>
.. <dir>
CONFIG00.CPC 3872
DEFAULT.CPC 3872
FLTSTICK.CPC 3872
JOYSTICK.CPC 3872
JOYSTICK.STD 182
KEYBOARD.CPC 3872
MOUSE.CPC 3872
MOUSE.STD 167
NOVICE.CPC 3872
SIDEWIND.CPC 3872
TMASTER.CPC 3872
VIO1.CPC 3872
VIO2.CPC 3872
File listing for F:\KEATING
. <dir>
.. <dir>
TRA1001S.SFL 27027
TRA1002S.SFL 171127
TRA1003S.SFL 136723
TRA1004S.SFL 180119
TRA1005S.SFL 54247
TRA1006S.SFL 144527
TRA1007S.SFL 96779
TRA1008S.SFL 109287
TRA1009.SFL 111079
TRA1009S.SFL 55173
TRA2001S.SFL 189931
TRA2002S.SFL 214351
TRA2003S.SFL 78107
TRA2004S.SFL 101767
TRA2005S.SFL 72795
TRA2006S.SFL 53643
TRA2007S.SFL 51051
TRA2008S.SFL 121423
TRA3001S.SFL 167419
TRA3002S.SFL 286959
TRA3003S.SFL 21891
TRA3004S.SFL 188471
TRA3005S.SFL 80375
TRA3006S.SFL 42039
TRA3007S.SFL 56291
TRA4001S.SFL 96139
TRA4002S.SFL 149259
TRA4003S.SFL 18151
TRA4004S.SFL 85337
TRA4005S.SFL 101047
TRA4006S.SFL 124023
TRA4007S.SFL 38795
TRA4008S.SFL 93495
TRA4009S.SFL 42471
TRA4010S.SFL 137935
TRA4011S.SFL 144255
TRA4012S.SFL 37693
TRA4013S.SFL 22229
TRAIN01S.SFL 10303
TRAIN02S.SFL 21497
TRAIN03S.SFL 14545
TRAIN04S.SFL 17587
TRAIN1.SFL 25663
TRAIN2.SFL 45475
TRAIN3.SFL 41615
TRAIN4.SFL 46791
File listing for F:\LAUNCH
. <dir>
.. <dir>
LAUNCH.SHP 6914
LAUNCH6.SHP 20446
SUPANM.SHP 5591
SUPANM6.SHP 15540
File listing for F:\MEK
. <dir>
.. <dir>
File listing for F:\MERCS
. <dir>
.. <dir>
DATABASE.MW2 16198967
DEFNET.CFG 200
DOS4GW.EXE 265420
FLTSTCK.MAP 8326
GAMEKEY.MAP 4176
INPUT.MAP 5324
INPUTW.MAP 3096
IPXADR.EXE 9968
JOYSTICK.MAP 7647
KEYBOARD.MAP 7225
LSLCHECK.EXE 8462
MERCNET.EXE 13332
MERCPPP.BAT 4341
MERCS.EXE 31989
MERCSW.DLL 854528
MERCSWIN.EXE 35840
MODEM.LST 146
MOUSE.MAP 7466
MSJSTICK.MAP 8323
MSS32.DLL 136192
MW2.DLL 882176
MW2.EXE 944149
MW2.INI 4959
MW2.PRJ 41479843
MW2586.CFG 84
MW2DIF.CFG 23
MW2PRM.CFG 12
MW2SHELL.DLL 791552
MW2SHELL.EXE 962175
NETKEY.MAP 0
NETSHELL.EXE 453425
NETSHELL.INI 5825
PPPSHARE.EXE 192229
SERVERS.TXT 36
SETSOUND.BAT 40
SKYGND.PAR 13263
SMACKW32.DLL 60416
WAIL32.DLL 114688
WATPING.EXE 75416
File listing for F:\MISSIONS
. <dir>
.. <dir>
AVO1.MWM 44544
BAS1.MWM 46592
BAS2.MWM 41472
BAS3.MWM 39936
BAS4.MWM 44544
BAS5.MWM 43520
FAL1.MWM 47616
FRE1.MWM 50176
FRE2.MWM 47616
FRE3.MWM 55808
FRE4.MWM 62976
FRE5.MWM 48128
FRE6.MWM 43520
FRE7.MWM 38912
FRE8.MWM 39424
FREA.MWM 50176
FREB.MWM 51200
KIN1.MWM 71680
File listing for F:\RMG
. <dir>
.. <dir>
AIRPORT.BWD 1072
BASE1.BWD 5752
BASEA.BWD 1768
CHEMPLNT.BWD 2432
DRPSHP1.BWD 500
DRPSHP2.BWD 500
DRPSHP3.BWD 500
DRPSHP4.BWD 500
DRPSHP5.BWD 696
FIELDHQ.BWD 1104
FIREBASE.BWD 4424
GRDTOWER.BWD 1452
GREEK1.BWD 4092
HPG1.BWD 4424
INDPLNT2.BWD 5524
MINERIG.BWD 440
MIS0SCN1.BWD 2900
MIS0SCN2.BWD 4019
MIS0SCN3.BWD 5138
MIS0SCN4.BWD 5502
MIS1SCN1.BWD 2598
MIS1SCN2.BWD 3566
MIS1SCN3.BWD 4534
MIS1SCN4.BWD 5502
MIS2SCN1.BWD 2749
MIS2SCN2.BWD 4019
MIS2SCN3.BWD 5289
MIS2SCN4.BWD 6559
MIS3SCN1.BWD 2900
MIS3SCN2.BWD 4019
MIS3SCN3.BWD 5138
MIS3SCN4.BWD 5502
MIS4SCN1.BWD 2598
MIS4SCN2.BWD 3264
MIS4SCN3.BWD 3930
MIS4SCN4.BWD 4596
MIS5SCN1.BWD 2749
MIS5SCN2.BWD 3415
MIS5SCN3.BWD 4081
MIS5SCN4.BWD 4747
MIS6SCN1.BWD 2900
MIS6SCN2.BWD 3566
MIS6SCN3.BWD 4232
MIS6SCN4.BWD 4596
MIS7SCN1.BWD 2900
MIS7SCN2.BWD 3566
MIS7SCN3.BWD 4232
MIS7SCN4.BWD 4596
MIS8SCN1.BWD 2598
MIS8SCN2.BWD 3566
MIS8SCN3.BWD 4534
MIS8SCN4.BWD 5502
MIS9SCN1.BWD 2749
MIS9SCN2.BWD 4019
MIS9SCN3.BWD 5289
MIS9SCN4.BWD 6559
NUKEPLNT.BWD 1104
OFFICE.BWD 440
OFFICE1.BWD 440
PROCESS1.BWD 2764
PUMPSTN3.BWD 2432
RDRAREA1.BWD 2432
RESEXTR.BWD 1616
SMSTK.BWD 2432
TRAINCTR.BWD 1812
URBNSPCL.BWD 424
File listing for F:\SMK
. <dir>
.. <dir>
AAMMO.SMK 273564
AAMMO1.SMK 300700
AAMMO2.SMK 256156
AANI.SMK 107496
AASA.SMK 94268
AATL.SMK 116900
AAWE.SMK 109960
ABHK.SMK 118196
ABMB.SMK 118484
ACAT.SMK 156988
ACAU.SMK 131904
ACEN.SMK 101584
ACIC.SMK 117444
ACMD.SMK 114216
ACNT.SMK 121168
ACOM.SMK 114216
ACRB.SMK 120348
ACYC.SMK 121956
ADRA.SMK 111860
ADRW.SMK 132296
AELE.SMK 108360
AEQUIP1.SMK 194336
AEQUIP2.SMK 153492
AEQUIPT.SMK 160700
AEQUIPT1.SMK 194336
AEQUIPT2.SMK 148416
AEXE.SMK 103196
AFLA.SMK 135736
AFRM.SMK 119360
AGRG.SMK 117756
AGRM.SMK 129324
AGRZ.SMK 113932
AHAT.SMK 125172
AHCH.SMK 118472
AHIL.SMK 125068
AHLB.SMK 142828
AHOR.SMK 106144
AISB.SMK 98056
AJAG.SMK 149660
AJAV.SMK 124496
AJEN.SMK 120416
AJNR.SMK 129040
AKDK.SMK 116920
AKTF.SMK 94108
ALASER.SMK 109856
ALASER1.SMK 144696
ALASER2.SMK 101788
ALBK.SMK 137652
AMAU.SMK 155204
AMDG.SMK 130784
AMISSLE.SMK 212200
AMISSLE1.SMK 226528
AMISSLE2.SMK 199768
AMON.SMK 107536
ANGA.SMK 113640
ANVA.SMK 110692
AORI.SMK 102356
APLY.SMK 114216
APNT.SMK 113680
APROJ.SMK 165952
APROJ1.SMK 192144
APROJ2.SMK 148056
APTM.SMK 114260
AQUD.SMK 98620
ARAK.SMK 123792
ARAV.SMK 105128
ASAL.SMK 104840
ASEN.SMK 94732
ASMN.SMK 124108
ASTK.SMK 155416
ASTM.SMK 134520
ATBR.SMK 144704
ATHG.SMK 122552
ATRE.SMK 99656
AURB.SMK 122156
AVIC.SMK 117080
AVIN.SMK 97312
AWHK.SMK 117176
AWHW.SMK 96964
AWLF.SMK 89216
AZEU.SMK 119528
BAACCP.SHP 2094
BAAMMO.SHP 1961
BABUY.SHP 1673
BACCEPT.SHP 1698
BAENRG.SHP 2043
BAEQUP.SHP 1978
BAEXIT.SHP 1712
BAMISS.SHP 2134
BAPROJ.SHP 1750
BARMDLR.SHP 3208
BASELL.SHP 1621
BCACCP.SHP 2015
BCADD.SHP 1618
BCAMMO.SHP 1961
BCENRG.SHP 2043
BCEQUP.SHP 1978
BCEXIT.SHP 1635
BCLEARA.SHP 2412
BCLEARI.SHP 1914
BCMISS.SHP 2134
BCNEXT.SHP 1198
BCPREV.SHP 1227
BCPROJ.SHP 1750
BCREM.SHP 2219
BDREXIT.SHP 1569
BDRNEXT.SHP 1240
BDRPREV.SHP 1266
BET1BRF1.SMK 598596
BET2BRF1.SMK 472328
BET3BRF1.SMK 309696
BET4BRF1.SMK 415332
BET5BRF1.SMK 194164
BIG1BRF1.SMK 373216
BMARMS.SHP 6944
BMCUST.SHP 5851
BMDUTY.SHP 53630
BMECASGN.SHP 3033
BMECEXIT.SHP 2892
BMEXIT.SHP 1852
BMFACT.SHP 6438
BMMECH.SHP 5562
BMREPR.SHP 6037
BMWGRP.SHP 7929
BNEXTR.SHP 1262
BPREVR.SHP 1295
BREPAIRA.SHP 2616
BREPAIRI.SHP 2174
BUZ1BRF1.SMK 325904
BWASSN.SHP 2171
BWDEFL.SHP 2251
BWEXIT.SHP 1698
BWNEXT.SHP 1269
BWPREV.SHP 1295
CASHBOX.SHP 884
CASHBOXC.SHP 884
CASHBOXD.SHP 877
COMSTAR.SHP 5810
COMSTAR.SMK 402104
CSTBOXAA.SHP 1730
CSTBOXAB.SHP 2290
CSTBOXAC.SHP 1527
CSTBOXAD.SHP 10801
CSTBOXAE.SHP 3018
CSTBTNAA.SHP 643
CSTBTNAB.SHP 864
CSTBTNAC.SHP 681
CSTBTNAD.SHP 1525
CSTBTNAE.SHP 1545
CSTBTNAF.SHP 595
CSTBTNAG.SHP 493
CSTBTNAH.SHP 656
CSTBTNBA.SHP 580
CSTBTNBB.SHP 725
CSTBTNBC.SHP 596
CSTBTNBD.SHP 1307
CSTBTNBE.SHP 1308
CSTBTNBF.SHP 503
CSTBTNBG.SHP 417
CSTBTNBH.SHP 518
CSTCTORA.SHP 1061
CSTHEADA.SHP 477
CSTLARMA.SHP 1428
CSTLLEGA.SHP 2604
CSTLTORA.SHP 1265
CSTMECH.SHP 10446
CSTRARMA.SHP 1446
CSTRLEGA.SHP 2630
CSTRTORA.SHP 1278
CTOR.SHP 18471
DACCEPT.SHP 1704
DAMMEK.SHP 104756
DCLEARA.SHP 2424
DCLEARI.SHP 1926
DMON.SMK 41732
DNEXTR.SHP 1320
DOM1BRF1.SMK 294144
DPREVR.SHP 1353
DRACONIS.SHP 16677
DREPAIRA.SHP 2628
DREPAIRI.SHP 2186
DROP.SMK 8404
DSBD.SHP 5931
DSBE.SHP 1596
DSBF.SHP 6995
DSBI.SHP 5843
DSBM.SHP 7998
DSBR.SHP 6607
DSNDUTY.SHP 5932
DSNLNCH.SHP 7998
DSNMLAB.SHP 6904
DTHING.SMK 5964
FEDCOM.SHP 22422
FREERASS.SHP 15246
GRA1BRF1.SMK 209424
GRA2BRF1.SMK 192564
GRA3BRF1.SMK 177208
GRA4BRF1.SMK 217876
GRA5BRF1.SMK 189724
HEAD.SHP 4500
IAAACCP.SHP 1860
IAAEXIT.SHP 1486
IAALNCH.SHP 4091
IAAMISP.SHP 4408
IAAMLAB.SHP 2218
IAANEXT.SHP 1222
IAAPREV.SHP 1248
IABACCP.SHP 2061
IABAPARA.SHP 7
IABCCP.SHP 7
IABEXIT.SHP 1559
IABPARA.SHP 4500
IABPASS.SHP 3865
INAMMO.SHP 2072
INENRG.SHP 2146
INEQUP.SHP 2096
INEXIT.SHP 1638
INMECH.SHP 1792
INMISS.SHP 2127
INPROJ.SHP 1877
IVA1BRF1.SMK 325376
IVA2BRF1.SMK 288792
IVA3BRF1.SMK 251436
IVA4BRF1.SMK 288792
LAAARROW.SHP 199
LAADEFD.SHP 1834
LAADEST.SHP 1927
LAAEASY.SHP 1466
LAAHARD.SHP 1508
LAAMED.SHP 1456
LAAON.SHP 1269
LAARECN.SHP 1707
LABE.SHP 1676
LARM.SHP 18521
LBAD.SHP 3453
LBAL.SHP 4174
LBAR.SHP 4210
LBAS.SHP 3430
LBAV.SHP 1944
LBBA.SHP 3734
LBBDB.SHP 3754
LBBE.SHP 1682
LBBN.SHP 4491
LBCSP.SHP 4027
LBRP.SHP 3910
LLEG.SHP 48096
LOGO.SMK 49352
LSHIP.SMK 460252
LTOR.SHP 11644
LUT1BRF1.SMK 511368
LUT2BRF1.SMK 488196
LUT3BRF1.SMK 424160
LUT4BRF1.SMK 359940
LUT5BRF1.SMK 493716
LUT6BRF1.SMK 314200
MBAY.SMK 447424
MCC1BRF1.SMK 1136636
MCC2BRF1.SMK 735764
MCC3BRF1.SMK 476892
MCC4BRF1.SMK 426992
MCC5BRF1.SMK 434692
MCC6BRF1.SMK 261844
MCC7BRF1.SMK 401172
MDEATH.SMK 2529164
MEJECT.SMK 3347556
MEND.SMK 17776828
MFACCP.SHP 2061
MFBB.SHP 1579
MFBC.SHP 1318
MFBD.SHP 1133
MFBE.SHP 1557
MFBN.SHP 1186
MFBP.SHP 1219
MFBS.SHP 1506
MINTRO.SMK 16372052
MLAND.SMK 2514628
MLAND2.SMK 2577400
MLBC.SHP 1798
MLBI.SHP 1338
MLETTER.SMK 875188
MLGHTB.SMK 27884
MLGHTC.SMK 12572
MLIGHTA.SMK 36024
MLIGHTB.SMK 85976
MLIGHTC.SMK 80956
MMON.SMK 157628
MPOOR.SMK 2248312
MPOORW.SMK 2185168
MRICH.SMK 3808216
MTO.SMK 2721984
NODATA.SMK 260560
NSEXIT.SHP 1483
OCBCA.SHP 1833
OCBCE.SHP 1455
OCBCN.SHP 1093
OCBCP.SHP 1126
OCBED.SHP 2403
OCBFE.SHP 1798
OCBHE.SHP 1483
OCBHF.SHP 1498
OCBHH.SHP 1610
OCBIA.SHP 1875
OCBIE.SHP 1433
OCBIEN.SHP 1974
OCBIEQ.SHP 1898
OCBIM.SHP 2009
OCBIME.SHP 1741
OCBIP.SHP 1683
OCCFE.SHP 1355
OFFDOORA.SMK 132324
OFFDOORB.SMK 77984
OFFDOORC.SMK 132064
OFFDOORD.SMK 77672
OFFLOGO.SMK 684384
OMON.SMK 104084
OOCONT.SHP 8568
OOEXIT.SHP 1283
OOFINA.SHP 9439
OOINVT.SHP 8724
OOPERS.SHP 8461
ORACCP.SHP 1763
OUT1BRF1.SMK 367364
OUT2BRF1.SMK 246328
OUT3BRF1.SMK 332672
OUT4BRF1.SMK 241588
RARM.SHP 18123
RCOMSTAR.SMK 402104
REC1BRF1.SMK 273120
REC2BRF1.SMK 272000
REV1BRF1.SMK 171304
RLEG.SHP 49332
ROG1BRF1.SMK 296164
ROTR.SHP 4208
RTOR.SHP 11454
SAVEEXIT.SHP 1474
SAVELOAD.SHP 1678
SAVESAVE.SHP 1644
SDOORA.SMK 19868
SDOORAB.SMK 19808
SDOORB.SMK 29980
SHIP.SMK 460252
SHIPS.SMK 150524
SIG1BRF1.SMK 50200
SINST.SHP 9459
SLIGHTB.SMK 15500
SMECHW.SHP 9269
SMERCS.SHP 9755
SMON.SMK 78512
SMRCNT.SHP 9165
SOL1BRF1.SMK 331240
SOL2BRF1.SMK 312260
SOL3BRF1.SMK 354592
SOL4BRF1.SMK 386268
SOL5BRF1.SMK 321756
SOL6BRF1.SMK 304684
SOLARSYS.SMK 108352
SOPTNS.SHP 8982
SPA1BRF1.SMK 161148
SPA2BRF1.SMK 261440
SPA3BRF1.SMK 188112
STARMAP.SMK 36688
TRA1BRF1.SMK 209092
TRA2BRF1.SMK 239388
TRA3BRF1.SMK 274988
TRA4BRF1.SMK 232880
WOL1BRF1.SMK 409392
WOL2BRF1.SMK 610920
WOL3BRF1.SMK 318280
WOL4BRF1.SMK 412092
WOL5BRF1.SMK 223888
WOU1BRF1.SMK 239216
File listing for F:\SND
. <dir>
.. <dir>
ADRV688.DIG 11278
AILDRVR.LST 16131
DBSOUND.LST 2955
DOS4GW.EXE 265420
JAMMER.DIG 3219
PROAUDIO.DIG 2127
RAP10.DIG 2849
SAMPLE.AD 3662
SAMPLE.BNK 10780
SAMPLE.OPL 3242
SB16.DIG 2812
SBLASTER.DIG 2984
SBPRO.DIG 2763
SETSOUND.EXE 255244
SETSOUND.WAV 12076
SNDSCAPE.DIG 4171
SNDSYS.DIG 3332
ULTRA.DIG 9478
File listing for F:\SP16
. <dir>
.. <dir>
ABOUTACT.BMP 153718
ABOUTD2.BMP 2758
ABOUTU2.BMP 2758
ELECTD2.BMP 2758
ELECTU2.BMP 2758
EXITD1.BMP 2758
EXITD2.BMP 2758
EXITU1.BMP 2758
EXITU2.BMP 2758
FALL.BMP 153718
FALLDN.BMP 8856
FALLUP.BMP 8856
GAMESD2.BMP 2758
GAMESU2.BMP 2758
GPREVDN.BMP 2758
GPREVUP.BMP 2758
HYPERDN.BMP 16080
HYPERUP.BMP 16080
I76DN.BMP 16248
I76UP.BMP 16080
INSTALD1.BMP 2758
INSTALD2.BMP 2758
INSTALU1.BMP 2758
INSTALU2.BMP 2758
MECH.BMP 153718
MORED1.BMP 2758
MOREU1.BMP 2758
MPDN.BMP 8960
MPUP.BMP 8960
PLAYD1.BMP 2758
PLAYD2.BMP 2758
PLAYU1.BMP 2758
PLAYU2.BMP 2758
PREVIEW.BMP 153718
RET1DN.BMP 5496
RET1UP.BMP 5432
RET2DN.BMP 3180
RET2UP.BMP 3180
RET3DN.BMP 3180
RET3UP.BMP 3180
SCREEN.BMP 153718
TCDN.BMP 16080
TCUP.BMP 15996
THELPD2.BMP 2758
THELPU2.BMP 2758
UNINSTD2.BMP 2758
UNINSTU2.BMP 2758
File listing for F:\SP256
. <dir>
.. <dir>
ABOUTACT.BMP 308278
ABOUTA~1.BMP 173878
ABOUTD2.BMP 6358
ABOUTU2.BMP 6358
ELECTD2.BMP 6358
ELECTU2.BMP 6358
EXITD1.BMP 6358
EXITD2.BMP 6358
EXITU1.BMP 6358
EXITU2.BMP 6358
FALL.BMP 308278
FALLDN.BMP 18758
FALLUP.BMP 18758
GAMESD2.BMP 6358
GAMESU2.BMP 6358
GPREVDN.BMP 6358
GPREVUP.BMP 6358
HYPERDN.BMP 32074
HYPERUP.BMP 32074
I76DN.BMP 32402
I76UP.BMP 32074
INSTALD1.BMP 6358
INSTALD2.BMP 6358
INSTALU1.BMP 6358
INSTALU2.BMP 6358
MECH.BMP 308278
MORED1.BMP 6358
MOREU1.BMP 6358
MPDN.BMP 19098
MPUP.BMP 19098
PLAYD1.BMP 6358
PLAYD2.BMP 6358
PLAYU1.BMP 6358
PLAYU2.BMP 6358
PREVIEW.BMP 308278
RET1DN.BMP 11958
RET1UP.BMP 11958
RET2DN.BMP 7334
RET2UP.BMP 7334
RET3DN.BMP 7334
RET3UP.BMP 7334
SCREEN.BMP 308278
TCDN.BMP 32074
TCUP.BMP 32074
THELPD2.BMP 6358
THELPU2.BMP 6358
UNINSTD2.BMP 6358
UNINSTU2.BMP 6358
File listing for F:\TOOLS
. <dir>
.. <dir>
DEM1 <dir>
DEM2 <dir>
DOS4GW.EXE 265420
EN00STAR.BWD 152
EN01STAR.BWD 152
EN02STAR.BWD 52
EN03STAR.BWD 52
EN04STAR.BWD 52
EN05STAR.BWD 52
EN06STAR.BWD 52
EN07STAR.BWD 52
EN08STAR.BWD 152
GROUPER.EXE 85900
MAKEBOTH.BAT 263
MW2DOC.HTM 84821
STRIPWLD.EXE 38992
TAR.EXE 35231
WASM.EXE 179981
File listing for F:\TOOLS\DEM1
. <dir>
.. <dir>
DEM1.WLD 18
DEM1ARE1.WLD 968
DEM1ARE2.WLD 966
DEM1ARE3.WLD 966
DEM1ARE4.WLD 968
DEM1ARE5.WLD 966
DEM1ARE6.WLD 966
DEM1ARE7.WLD 966
DEM1ARE8.WLD 966
DEM1ARE9.WLD 966
DEM1BRF0.TXT 162
DEM1BRF1.TXT 162
DEM1BRF2.TXT 162
DEM1FRM1.WLD 232
DEM1LIM0.TXT 20
DEM1LIM1.TXT 1
DEM1LV01.WLD 66
DEM1LV11.WLD 66
DEM1MAP1.WLD 31379
DEM1NAME.TXT 14
DEM1PLT1.WLD 399
DEM1SCN1.WLD 1670
DEM1ST01.WLD 62
DEM1ST11.WLD 67
DEM1WLD1.WLD 506
W10FPAL1.WLD 579
File listing for F:\TOOLS\DEM2
. <dir>
.. <dir>
CY0NPAL1.WLD 575
DEM2.WLD 18
DEM2ARE1.WLD 11236
DEM2BRF0.TXT 263
DEM2LIM0.TXT 24
DEM2LIM1.TXT 1
DEM2MAP1.WLD 31379
DEM2NAME.TXT 14
DEM2NAV0.WLD 73
DEM2NAV1.WLD 73
DEM2NAV2.WLD 73
DEM2NAV3.WLD 73
DEM2NAV4.WLD 73
DEM2NAV5.WLD 73
DEM2NAV6.WLD 73
DEM2NAV7.WLD 73
DEM2PLT1.WLD 406
DEM2SCN1.WLD 4715
DEM2ST01.WLD 64
DEM2ST11.WLD 65
DEM2ST21.WLD 67
DEM2ST31.WLD 66
DEM2ST41.WLD 63
DEM2ST51.WLD 63
DEM2ST61.WLD 64
DEM2ST71.WLD 61
DEM2WLD1.WLD 44
File listing for F:\VFX
. <dir>
.. <dir>
MCGA.DLL 7056
VESA480.DLL 19028
VESA768.DLL 20948
VFXHD.BIN 48642
VFXJK.BIN 24863
VFXTM.BIN 48450
File listing for E:\Programs\MechVM-win32-2009-11-29\games\mw2-mercs-dos
. <dir>
.. <dir>
AdvApi42.dll 90112
campaign.xml 3749
CFGS <dir>
CPU.EXE 5802
DEFNET.CFG 200
DLL <dir>
DOS4GW.EXE 265420
FIXBOOT.EXE 70425
FLTSTCK.MAP 8326
GAMEKEY.MAP 4176
gdi42.dll 77824
GIDDI <dir>
HELP.BAT 15
HELP.TXT 55876
INPUT.MAP 5324
INPUTW.MAP 3096
install-report.txt 0
INSTALL.EXE 276696
INSTALL.PIF 967
INWIN.EXE 5984
IPXADR.EXE 9968
IVE.EXE 211414
JOYSTICK.MAP 7647
Kernel42.dll 102400
KEYBOARD.MAP 7225
LSLCHECK.EXE 8462
MEK <dir>
MERCNET.EXE 13332
MERCPPP.BAT 4341
MERCS.EXE 31989
MERCSW.DLL 854528
MERCSWIN.EXE 35840
MISSIONS <dir>
MODEM.LST 146
MOUSE.MAP 7466
mouse2kv.exe 15759
MSJSTICK.MAP 8323
MSS32.DLL 136192
MW2.DLL 882176
MW2.EXE 944149
MW2.INI 4959
MW2.PRJ 41479843
MW2486.CFG 84
MW2586.CFG 84
mw2car.cfg 214
MW2DIF.CFG 23
MW2PRM.CFG 704
MW2SHELL.DLL 791552
MW2SHELL.EXE 962175
mw2snd.cfg 84
NETKEY.MAP 0
NETSHELL.EXE 453425
NETSHELL.INI 5825
nolfb.asm 1988
nolfb.com 130
PPPSHARE.EXE 192229
PRODUCT.INI 204
readmeXP.txt 907
REGISTER.EXE 162516
RMG <dir>
SERVERS.TXT 36
SETSOUND.BAT 40
SETUP.CFG 266686
SHELLMER.CFG 57380
SKYGND.PAR 13263
SMACKW32.DLL 60416
SMK <dir>
SND <dir>
SOUNDDRV.EXE 96305
VESACHK.EXE 9574
VFX <dir>
WAIL32.DLL 114688
WATPING.EXE 75416
_mw2-mercs.bat 154
File listing for E:\Programs\MechVM-win32-2009-11-29\games\mw2-mercs-dos\CFGS
. <dir>
.. <dir>
File listing for E:\Programs\MechVM-win32-2009-11-29\games\mw2-mercs-dos\DLL
. <dir>
.. <dir>
DWANGO.DLL 50070
IPX.DLL 16764
MODEM.DLL 20343
SERIAL.DLL 17267
WAT.DLL 61882
File listing for E:\Programs\MechVM-win32-2009-11-29\games\mw2-mercs-dos\GIDDI
. <dir>
.. <dir>
AVENGER.CPC 3872
AVENGER.DLL 8843
AVENGER.TXT 4551
CONFIG00.CPC 3872
CONFIG01.CPC 3872
CONFIG02.CPC 3872
CONFIG03.CPC 3872
CONFIG04.CPC 3872
DEFAULT.CPC 3872
FLTSTCK.CPC 3872
FLTSTCK.DLL 6831
FLTSTCK.STD 174
FLTSTICK.CPC 3872
JOYSTICK.CPC 3872
JOYSTICK.DLL 4870
JOYSTICK.STD 189
KEYBDENG.CPC 3872
KEYBOARD.CPC 3872
KEYBOARD.DLL 8207
MOUSE.CPC 3872
MOUSE.DLL 4760
MOUSE.STD 174
MSJSTICK.CPC 3872
MSJSTICK.DLL 6863
MSJSTICK.STD 178
NOVICE.CPC 3872
SIDEWIND.CPC 3872
SIDEWNDR.CPC 3872
SIDEWNDR.DLL 6072
SIDEWNDR.STD 177
SIDWINDR.CPC 0
TMASTER.CPC 3872
TMASTER.DLL 6957
TMASTER.STD 173
VFX1.CPC 3872
VFX1.DLL 3222
VIO1.CPC 3872
VIO1.DLL 4341
VIO2.CPC 3872
VIO2.DLL 4341
VPILOT.CPC 3872
VPILOT.DLL 6975
VPILOT.TXT 1120
WINGMAN.CPC 3872
WINGMAN.DLL 6941
File listing for E:\Programs\MechVM-win32-2009-11-29\games\mw2-mercs-dos\MEK
. <dir>
.. <dir>
File listing for E:\Programs\MechVM-win32-2009-11-29\games\mw2-mercs-dos\MISSIONS
. <dir>
.. <dir>
AVO1.MWM 44544
BAS1.MWM 46592
BAS2.MWM 41472
BAS3.MWM 39936
BAS4.MWM 44544
BAS5.MWM 43520
FAL1.MWM 47616
FRE1.MWM 50176
FRE2.MWM 47616
FRE3.MWM 55808
FRE4.MWM 62976
FRE5.MWM 48128
FRE6.MWM 43520
FRE7.MWM 38912
FRE8.MWM 39424
FREA.MWM 50176
FREB.MWM 51200
KIN1.MWM 71680
File listing for E:\Programs\MechVM-win32-2009-11-29\games\mw2-mercs-dos\RMG
. <dir>
.. <dir>
AIRPORT.BWD 1072
BASE1.BWD 5752
BASEA.BWD 1768
CHEMPLNT.BWD 2432
DRPSHP1.BWD 500
DRPSHP2.BWD 500
DRPSHP3.BWD 500
DRPSHP4.BWD 500
DRPSHP5.BWD 696
FIELDHQ.BWD 1104
FIREBASE.BWD 4424
GRDTOWER.BWD 1452
GREEK1.BWD 4092
HPG1.BWD 4424
INDPLNT2.BWD 5524
MINERIG.BWD 440
MIS0SCN1.BWD 2900
MIS0SCN2.BWD 4019
MIS0SCN3.BWD 5138
MIS0SCN4.BWD 5502
MIS1SCN1.BWD 2598
MIS1SCN2.BWD 3566
MIS1SCN3.BWD 4534
MIS1SCN4.BWD 5502
MIS2SCN1.BWD 2749
MIS2SCN2.BWD 4019
MIS2SCN3.BWD 5289
MIS2SCN4.BWD 6559
MIS3SCN1.BWD 2900
MIS3SCN2.BWD 4019
MIS3SCN3.BWD 5138
MIS3SCN4.BWD 5502
MIS4SCN1.BWD 2598
MIS4SCN2.BWD 3264
MIS4SCN3.BWD 3930
MIS4SCN4.BWD 4596
MIS5SCN1.BWD 2749
MIS5SCN2.BWD 3415
MIS5SCN3.BWD 4081
MIS5SCN4.BWD 4747
MIS6SCN1.BWD 2900
MIS6SCN2.BWD 3566
MIS6SCN3.BWD 4232
MIS6SCN4.BWD 4596
MIS7SCN1.BWD 2900
MIS7SCN2.BWD 3566
MIS7SCN3.BWD 4232
MIS7SCN4.BWD 4596
MIS8SCN1.BWD 2598
MIS8SCN2.BWD 3566
MIS8SCN3.BWD 4534
MIS8SCN4.BWD 5502
MIS9SCN1.BWD 2749
MIS9SCN2.BWD 4019
MIS9SCN3.BWD 5289
MIS9SCN4.BWD 6559
NUKEPLNT.BWD 1104
OFFICE.BWD 440
OFFICE1.BWD 440
PROCESS1.BWD 2764
PUMPSTN3.BWD 2432
RDRAREA1.BWD 2432
RESEXTR.BWD 1616
SMSTK.BWD 2432
TRAINCTR.BWD 1812
URBNSPCL.BWD 424
File listing for E:\Programs\MechVM-win32-2009-11-29\games\mw2-mercs-dos\SMK
. <dir>
.. <dir>
AAMMO.SMK 273564
AAMMO1.SMK 300700
AAMMO2.SMK 256156
AANI.SMK 107496
AASA.SMK 94268
AATL.SMK 116900
AAWE.SMK 109960
ABHK.SMK 118196
ABMB.SMK 118484
ACAT.SMK 156988
ACAU.SMK 131904
ACEN.SMK 101584
ACIC.SMK 117444
ACMD.SMK 114216
ACNT.SMK 121168
ACOM.SMK 114216
ACRB.SMK 120348
ACYC.SMK 121956
ADRA.SMK 111860
ADRW.SMK 132296
AELE.SMK 108360
AEQUIP1.SMK 194336
AEQUIP2.SMK 153492
AEQUIPT.SMK 160700
AEQUIPT1.SMK 194336
AEQUIPT2.SMK 148416
AEXE.SMK 103196
AFLA.SMK 135736
AFRM.SMK 119360
AGRG.SMK 117756
AGRM.SMK 129324
AGRZ.SMK 113932
AHAT.SMK 125172
AHCH.SMK 118472
AHIL.SMK 125068
AHLB.SMK 142828
AHOR.SMK 106144
AISB.SMK 98056
AJAG.SMK 149660
AJAV.SMK 124496
AJEN.SMK 120416
AJNR.SMK 129040
AKDK.SMK 116920
AKTF.SMK 94108
ALASER.SMK 109856
ALASER1.SMK 144696
ALASER2.SMK 101788
ALBK.SMK 137652
AMAU.SMK 155204
AMDG.SMK 130784
AMISSLE.SMK 212200
AMISSLE1.SMK 226528
AMISSLE2.SMK 199768
AMON.SMK 107536
ANGA.SMK 113640
ANVA.SMK 110692
AORI.SMK 102356
APLY.SMK 114216
APNT.SMK 113680
APROJ.SMK 165952
APROJ1.SMK 192144
APROJ2.SMK 148056
APTM.SMK 114260
AQUD.SMK 98620
ARAK.SMK 123792
ARAV.SMK 105128
ASAL.SMK 104840
ASEN.SMK 94732
ASMN.SMK 124108
ASTK.SMK 155416
ASTM.SMK 134520
ATBR.SMK 144704
ATHG.SMK 122552
ATRE.SMK 99656
AURB.SMK 122156
AVIC.SMK 117080
AVIN.SMK 97312
AWHK.SMK 117176
AWHW.SMK 96964
AWLF.SMK 89216
AZEU.SMK 119528
BAACCP.SHP 2094
BAAMMO.SHP 1961
BABUY.SHP 1673
BACCEPT.SHP 1698
BAENRG.SHP 2043
BAEQUP.SHP 1978
BAEXIT.SHP 1712
BAMISS.SHP 2134
BAPROJ.SHP 1750
BARMDLR.SHP 3208
BASELL.SHP 1621
BCACCP.SHP 2015
BCADD.SHP 1618
BCAMMO.SHP 1961
BCENRG.SHP 2043
BCEQUP.SHP 1978
BCEXIT.SHP 1635
BCLEARA.SHP 2412
BCLEARI.SHP 1914
BCMISS.SHP 2134
BCNEXT.SHP 1198
BCPREV.SHP 1227
BCPROJ.SHP 1750
BCREM.SHP 2219
BDREXIT.SHP 1569
BDRNEXT.SHP 1240
BDRPREV.SHP 1266
BET1BRF1.SMK 598596
BET2BRF1.SMK 472328
BET3BRF1.SMK 309696
BET4BRF1.SMK 415332
BET5BRF1.SMK 194164
BIG1BRF1.SMK 373216
BMARMS.SHP 6944
BMCUST.SHP 5851
BMDUTY.SHP 53630
BMECASGN.SHP 3033
BMECEXIT.SHP 2892
BMEXIT.SHP 1852
BMFACT.SHP 6438
BMMECH.SHP 5562
BMREPR.SHP 6037
BMWGRP.SHP 7929
BNEXTR.SHP 1262
BPREVR.SHP 1295
BREPAIRA.SHP 2616
BREPAIRI.SHP 2174
BUZ1BRF1.SMK 325904
BWASSN.SHP 2171
BWDEFL.SHP 2251
BWEXIT.SHP 1698
BWNEXT.SHP 1269
BWPREV.SHP 1295
CASHBOX.SHP 884
CASHBOXC.SHP 884
CASHBOXD.SHP 877
COMSTAR.SHP 5810
COMSTAR.SMK 402104
CSTBOXAA.SHP 1730
CSTBOXAB.SHP 2290
CSTBOXAC.SHP 1527
CSTBOXAD.SHP 10801
CSTBOXAE.SHP 3018
CSTBTNAA.SHP 643
CSTBTNAB.SHP 864
CSTBTNAC.SHP 681
CSTBTNAD.SHP 1525
CSTBTNAE.SHP 1545
CSTBTNAF.SHP 595
CSTBTNAG.SHP 493
CSTBTNAH.SHP 656
CSTBTNBA.SHP 580
CSTBTNBB.SHP 725
CSTBTNBC.SHP 596
CSTBTNBD.SHP 1307
CSTBTNBE.SHP 1308
CSTBTNBF.SHP 503
CSTBTNBG.SHP 417
CSTBTNBH.SHP 518
CSTCTORA.SHP 1061
CSTHEADA.SHP 477
CSTLARMA.SHP 1428
CSTLLEGA.SHP 2604
CSTLTORA.SHP 1265
CSTMECH.SHP 10446
CSTRARMA.SHP 1446
CSTRLEGA.SHP 2630
CSTRTORA.SHP 1278
CTOR.SHP 18471
DACCEPT.SHP 1704
DAMMEK.SHP 104756
DCLEARA.SHP 2424
DCLEARI.SHP 1926
DMON.SMK 41732
DNEXTR.SHP 1320
DOM1BRF1.SMK 294144
DPREVR.SHP 1353
DRACONIS.SHP 16677
DREPAIRA.SHP 2628
DREPAIRI.SHP 2186
DROP.SMK 8404
DSBD.SHP 5931
DSBE.SHP 1596
DSBF.SHP 6995
DSBI.SHP 5843
DSBM.SHP 7998
DSBR.SHP 6607
DSNDUTY.SHP 5932
DSNLNCH.SHP 7998
DSNMLAB.SHP 6904
DTHING.SMK 5964
FEDCOM.SHP 22422
FREERASS.SHP 15246
GRA1BRF1.SMK 209424
GRA2BRF1.SMK 192564
GRA3BRF1.SMK 177208
GRA4BRF1.SMK 217876
GRA5BRF1.SMK 189724
HEAD.SHP 4500
IAAACCP.SHP 1860
IAAEXIT.SHP 1486
IAALNCH.SHP 4091
IAAMISP.SHP 4408
IAAMLAB.SHP 2218
IAANEXT.SHP 1222
IAAPREV.SHP 1248
IABACCP.SHP 2061
IABAPARA.SHP 7
IABCCP.SHP 7
IABEXIT.SHP 1559
IABPARA.SHP 4500
IABPASS.SHP 3865
INAMMO.SHP 2072
INENRG.SHP 2146
INEQUP.SHP 2096
INEXIT.SHP 1638
INMECH.SHP 1792
INMISS.SHP 2127
INPROJ.SHP 1877
IVA1BRF1.SMK 325376
IVA2BRF1.SMK 288792
IVA3BRF1.SMK 251436
IVA4BRF1.SMK 288792
LAAARROW.SHP 199
LAADEFD.SHP 1834
LAADEST.SHP 1927
LAAEASY.SHP 1466
LAAHARD.SHP 1508
LAAMED.SHP 1456
LAAON.SHP 1269
LAARECN.SHP 1707
LABE.SHP 1676
LARM.SHP 18521
LBAD.SHP 3453
LBAL.SHP 4174
LBAR.SHP 4210
LBAS.SHP 3430
LBAV.SHP 1944
LBBA.SHP 3734
LBBDB.SHP 3754
LBBE.SHP 1682
LBBN.SHP 4491
LBCSP.SHP 4027
LBRP.SHP 3910
LLEG.SHP 48096
LOGO.SMK 49352
LSHIP.SMK 460252
LTOR.SHP 11644
LUT1BRF1.SMK 511368
LUT2BRF1.SMK 488196
LUT3BRF1.SMK 424160
LUT4BRF1.SMK 359940
LUT5BRF1.SMK 493716
LUT6BRF1.SMK 314200
MBAY.SMK 447424
MCC2BRF1.SMK 735764
MCC3BRF1.SMK 476892
MCC4BRF1.SMK 426992
MCC5BRF1.SMK 434692
MCC6BRF1.SMK 261844
MCC7BRF1.SMK 401172
MDEATH.SMK 2529164
MEJECT.SMK 3347556
MEND.SMK 17776828
MFACCP.SHP 2061
MFBB.SHP 1579
MFBC.SHP 1318
MFBD.SHP 1133
MFBE.SHP 1557
MFBN.SHP 1186
MFBP.SHP 1219
MFBS.SHP 1506
MINTRO.SMK 16372052
MLAND.SMK 2514628
MLAND2.SMK 2577400
MLBC.SHP 1798
MLBI.SHP 1338
MLETTER.SMK 875188
MLGHTB.SMK 27884
MLGHTC.SMK 12572
MLIGHTA.SMK 36024
MLIGHTB.SMK 85976
MLIGHTC.SMK 80956
MMON.SMK 157628
MPOOR.SMK 2248312
MPOORW.SMK 2185168
MRICH.SMK 3808216
MTO.SMK 2721984
NODATA.SMK 260560
NSEXIT.SHP 1483
OCBCA.SHP 1833
OCBCE.SHP 1455
OCBCN.SHP 1093
OCBCP.SHP 1126
OCBED.SHP 2403
OCBFE.SHP 1798
OCBHE.SHP 1483
OCBHF.SHP 1498
OCBHH.SHP 1610
OCBIA.SHP 1875
OCBIE.SHP 1433
OCBIEN.SHP 1974
OCBIEQ.SHP 1898
OCBIM.SHP 2009
OCBIME.SHP 1741
OCBIP.SHP 1683
OCCFE.SHP 1355
OFFDOORA.SMK 132324
OFFDOORB.SMK 77984
OFFDOORC.SMK 132064
OFFDOORD.SMK 77672
OFFLOGO.SMK 684384
OMON.SMK 104084
OOCONT.SHP 8568
OOEXIT.SHP 1283
OOFINA.SHP 9439
OOINVT.SHP 8724
OOPERS.SHP 8461
ORACCP.SHP 1763
OUT1BRF1.SMK 367364
OUT2BRF1.SMK 246328
OUT3BRF1.SMK 332672
OUT4BRF1.SMK 241588
RARM.SHP 18123
RCOMSTAR.SMK 402104
REC1BRF1.SMK 273120
REC2BRF1.SMK 272000
REV1BRF1.SMK 171304
RLEG.SHP 49332
ROG1BRF1.SMK 296164
ROTR.SHP 4208
RTOR.SHP 11454
SAVEEXIT.SHP 1474
SAVELOAD.SHP 1678
SAVESAVE.SHP 1644
SDOORA.SMK 19868
SDOORAB.SMK 19808
SDOORB.SMK 29980
SHIP.SMK 460252
SHIPS.SMK 150524
SIG1BRF1.SMK 50200
SINST.SHP 9459
SLIGHTB.SMK 15500
SMECHW.SHP 9269
SMERCS.SHP 9755
SMON.SMK 78512
SMRCNT.SHP 9165
SOL1BRF1.SMK 331240
SOL2BRF1.SMK 312260
SOL3BRF1.SMK 354592
SOL4BRF1.SMK 386268
SOL5BRF1.SMK 321756
SOL6BRF1.SMK 304684
SOLARSYS.SMK 108352
SOPTNS.SHP 8982
SPA1BRF1.SMK 161148
SPA2BRF1.SMK 261440
SPA3BRF1.SMK 188112
STARMAP.SMK 36688
TRA1BRF1.SMK 209092
TRA2BRF1.SMK 239388
TRA3BRF1.SMK 274988
TRA4BRF1.SMK 232880
WOL1BRF1.SMK 409392
WOL2BRF1.SMK 610920
WOL3BRF1.SMK 318280
WOL4BRF1.SMK 412092
WOL5BRF1.SMK 223888
WOU1BRF1.SMK 239216
File listing for E:\Programs\MechVM-win32-2009-11-29\games\mw2-mercs-dos\SND
. <dir>
.. <dir>
ADRV688.DIG 11278
AILDRVR.LST 16131
DBSOUND.LST 2955
DIG.INI 188
DOS4GW.EXE 265420
JAMMER.DIG 3219
PROAUDIO.DIG 2127
RAP10.DIG 2849
SAMPLE.AD 3662
SAMPLE.BNK 10780
SAMPLE.OPL 3242
SB16.DIG 2812
SBLASTER.DIG 2984
SBPRO.DIG 2763
SETSOUND.EXE 255244
SETSOUND.WAV 12076
SNDSCAPE.DIG 4171
SNDSYS.DIG 3332
ULTRA.DIG 9478
File listing for E:\Programs\MechVM-win32-2009-11-29\games\mw2-mercs-dos\VFX
. <dir>
.. <dir>
MCGA.DLL 7056
VESA480.DLL 19028
VESA768.DLL 20948
VFXHD.BIN 48642
VFXJK.BIN 24863
VFXTM.BIN 48450
MechVM's install looks ok. What operating system do you use for MechVM, or your own DosBox install? MechVM runs best on Windows XP and later. If you use Win9X, you need neither DosBox nor MechVM, you can run the game natively, per the game's install instructions.
It seems that DosBox is having trouble with your image/CD-ROM drive. I suppose the game crashes when you try to launch into a mission? Does it print a message? Which commands do you use to launch mercs?
FinalFantasyFanatic
I'm running Windows Seven, in Dosbox I type the following (printscreen):
And then I type Mercs to run it.
If I click on mercs comander or mercanary I get a black screen, if I click instant action, I get what I posted in the first screencap (first post).
The If I use Mech VM, I get a long pause until this error comes up:
I don't know how you manage to run MechVM as a 16-bit application. It is intended to run as Win32 process, and won't run otherwise. To run MechVM, just double-click MechVM.exe in Windows Explorer. Or start MechVM's DosBox, in MechVM's DosBox folder, by double-clicking DosBox.bat, then simply type "mercs".
As for running Mercs in DosBox, you have to install the game, and then run it from where you installed it. You can't run the game from CD.
FinalFantasyFanatic
Skyfaller wrote:I don't know how you manage to run MechVM as a 16-bit application. It is intended to run as Win32 process, and won't run otherwise. To run MechVM, just double-click MechVM.exe in Windows Explorer.
I extracted MechVM from it's archive and I've clicked the exe, I've tried deleting/re-extracting with the same result (I don't know why it's running in 16-bit).
Skyfaller wrote: Or start MechVM's DosBox, in MechVM's DosBox folder, by double-clicking DosBox.bat, then simply type "mercs".
I have less success with MechVM's Dosbox, I just get a black screen and no text. I can't type the command either, so I had to end task the DosBox.bat.
Skyfaller wrote:As for running Mercs in DosBox, you have to install the game, and then run it from where you installed it. You can't run the game from CD.
I was using the image for my Dosbox but when I use MechVM's dos/native options under play game, it asks for the cd despite having done the Install + import option in MechVM:
MechVM-2009-11-29
This is the message window for MechVM. If you close it, MechVM terminates.
GL Vendor: Microsoft Corporation
GL Renderer: GDI Generic
GL Version: 1.1.0
Running E:\Programs\MechVM-win32-2009-11-29\games\mw2-mercs-dos\_mw2-mercs.bat
E:\Programs\MechVM-win32-2009-11-29\games\mw2-mercs-dos>rem Linearen Framebuffer
 ausschalten
E:\Programs\MechVM-win32-2009-11-29\games\mw2-mercs-dos>nolfb
NOLFB by Ken Silverman (advsys.net/ken) 09/21/2002
E:\Programs\MECHVM~1\games\MW2-ME~1>rem DOS Sound Emulation starten
E:\Programs\MECHVM~1\games\MW2-ME~1>dosdrv
'dosdrv' is not recognized as an internal or external command,
operable program or batch file.
E:\Programs\MECHVM~1\games\MW2-ME~1>rem MechWarrior2 starten
E:\Programs\MECHVM~1\games\MW2-ME~1>rem mercs
E:\Programs\MECHVM~1\games\MW2-ME~1>mouse2kv 1024 768 8 8 mercs
MOUSE2KV v.1
Win2k/NTVDM/VESA/Mouse utility by Peter Maceluch
Designed to address the issues with mouse cursor being unable
to reach whole screen in some DOS programs in Win2k
Special thanks to Vlad ROMASCANU for MOUSESET sources this program
was based on.
Error: MechWarrior2: Mercenaries CD-Rom not found.
Process ended with code 0
Although if I use my CD image I made with clonecd it will run perfectly straight after the install in my dosbox, but once I close dosbox and open it later, the game will crash Dosbox if I try to play a mission (it also lacks sound at this point too).
At this point I'm wondering if this is a quirk MechVM or Mercs has with windows seven (I'll try to run in on XP tomorrow after work).
Please upload a screenshot of what you get when right-click MechVM.exe in Windows Explorer and select properties, and take screen shot that shows MechVM.exe in your Task Manager.
