Merchnet 2009
Jerad Gray
Merchnet 2009
Post by Jerad Gray »
Guess I should have asked about this a long time ago, but I just never got around to it.
Ever sense I first installed merc net I've gotten the following error message when trying to host a game "A3D_Int() failed, Check D3DERROR.TXT DirectX driver names not found in the windows registry" It pops up after hitting launch.
I have gotten this error in vista, 7, and under a windows 98 emulator.
I have tried both Titanium and regular (although I did patch my 1.05 to 1.1).
Any help?
PS: sorry if I just over looked how to make it work in the instructions.... or the instructions all together, I guess I have yet to find any lol.
Jerad Gray
Re: Merchnet 2009
So does noone have a clue then?
Re: Merchnet 2009
Myg might know, but on that one i forget how to fix it
Jerad Gray
Re: Merchnet 2009
May I ask how I would go about contacting Myg?
Re: Merchnet 2009
Write a private mail to Myg:
memberlist.php?mode=viewprofile&u=56
If you can't get it to work, the next version of MechVM will set up DOS MercNet from the Mercenaries' CD.
Jerad Gray
Re: Merchnet 2009
Skyfaller wrote:Write a private mail to Myg:
Titanium doesn't work for DOS does it? Which would mean I'd have to break out the 1.05 CD XD.
Oh and thanks for the link.
Re: Merchnet 2009
Replied to PM.
FreelancerMar
Re: Merchnet 2009
Post by FreelancerMar »
Microsoft Virtual pc 2007 emulates the S3 Trio chipset for video. This does not support D3D or 3dfx Acceleration. If you installed the D3D or 3Dfx files when you patched to 1.1 it most definately will NOT run.
I have a Windows ME Install through Virtual PC 2007. I checked the Hardware through the control panel to see what the emulated video card was before installing any merc patch past 1.06. I Still have not installed any later patches yet.
Bottem line. Microsoft Virtual PC 2007 Will not Emulate any Video hardware acceleration such as 3Dfx, OpenGL or D3D. It was not designed for 3D accelerated games. It was designed to run older non-game Windows applications that do not work on newer versions of windows. If A Game does not use 3D acceleration, it should run it without many issues. Just do not expect any 3D accelerated applications to work Through Microsoft Virtual PC 2007. I would also not expect any hardware acceleration to work on any future versions of virtual PC either.
