This raises the question of what Windows 7 means for the MW2 community.
DosBox 0.73: Problems with slow palette changes in full screen mode, followed by a crash or crackling noise, but NetMech, 31stCC, GBL and Mercs worked fine in windowed mode, even in 1024x768.
Titanium Trilogy: works with the distance and resolution patches, only GBL has the "Keshik max. defined tonnage"/overweight bug.
Battlepack: no luck here.
Windows/Pentium Editions:
31stCC: crashes when starting the sim
GBL: can't enter sim, my edition seems to have the mech lab disabled (Essential Collection, made in EU)
Mercs: Didn't run at all
Windows 7's XP mode is a special edition of VirtualPC that will be available with Windows 7 Professional, Windows 7 Ultimate or Windows 7 Enterprise and allows you to use Windows XP from Windows 7, supposedly with fewer installing and licensing hassle:
http://www.microsoft.com/windows/virtua ... nload.aspx
Your CPU needs special virtualization support. This is called Vanderpool Technology by Intel, or AMD-V by guess-who. There are tools to check this:
Intel
AMD
Unfortunately, my Windows 7 test system is not compatible with Virtual PC
Update: I was able to resolve the DosBox palette problems using
output=openglCode: Select all
output=surface
