Mercs On Beta 7 x64
Jerad Gray
Mercs On Beta 7 x64
Post by Jerad Gray »
Good news, Titanium Mercs still works on Windows Beta 7 x64 as long as you do everything you had to do with Vista.
(Although, changing the hud does seem to destabilize the game a little, and caused some sky glitches once, and the other time crashed the game the second I tried to change the hud).
Also the new 1.1 Merc Net continues to work, which is extreamly nice btw.
Re: Mercs On Beta 7 x64
Thanks for reporting this, glad to hear it.
Would you mind repeating the experiment with a DOS version under DosBox in Win7?
I already tested that skyfaller, 32bit version works great for netmech. I would assume it would be the same for other mech games in DOSBOX.
Oh yes, MMPD, I think you mentioned that already :oops: ... thanks for reminding me.
