Subfolder locations in PRJ
I was curious, at the way top of the PRJ file is that list of subfolders, and along next to each subfolder seems to be a set of numbers. When I changed the numbers around it refered to different locations in the PRJ.
Do you Skyfaller have any information I can study on this? That would be cool, actualy ADDING stuff rather than REPLACING.
Re: Subfolder locations in PRJ
I'm working on it. Adding files is more difficult than replacing them because the old directories do not have space left for new entries. Therefore, all directory entries must be copied into a larger table. I'm currently testing code that may accomplish that, given some more testing. I could share details, but it would a lot of technical stuff.
Fire away!I could share details, but it would a lot of technical stuff.
OK, you asked. It's all currently in a state of flux, with some parts contradicting others. I'm not really happy with it atm, but I'm currently a bit busy so I can't work these contradictions out. If you find mistakes, correct me please, this may cut from the time I spend on adding and replacing files in the PRJ. I'll edit this post later as we make progress.
(Last edited on 12/28/2008: added information on the symbol table following the directory definition)
- Notes
- C Record definitions, taken from MechWarriorIIPRJ.cpp
I'll test this out, see how it goes and report any former unknowns.
Thanks for helping me with this. Do you understand the record definitions (called structures in C)?
No prob.
atm, no. I'm still scaning through this, I take in info a little bit at a time. The offset locations and such make sense. But when you say "structures in C", you don't mean C/C++ do you? That's WAY beyond me
Well, yes, I mean C structures. But have no fear. It's the foldout "C record definitions". It simply lists the type first, then a field name, followed by optional repetitions in []. The latter define arrays. That's all there is to it. You can do it.
We're in race posting today
So... I don't need to know C++ to do his? Great then!
*Whpeew*...
*Whpeew*...
