How Do I Get 1.1 To Work?
Hello.
Wondering how I get the Mercenaries 1.1 patch to work properly on either DOSBox or the Windows XP Hook.
After I installed the 1.1, I installed the XP Hook and ran Mercs under Windows. But when I tried to play, it just went black and cut off. Any suggestions? :?
Re: How Do I Get 1.1 To Work?
Do not use 1.1 ... many times it kills mercs...
And 1.08 beta?
same prob many times..
I guess then I should have tried the upgrades back in Merc's hay-day, eh? Way back when there were these strange computers called "Windows 95/98" that could run Mercs without patches or DOSBox ... :roll:
It is not impossible for it to work, just unlikely. It does run for some people.
