Summoner Cockpit?
Summoner Cockpit?
Very interesting modification on Setubal.
- MW20001.GIF (32.11 KiB) Viewed 11131 times
- MW20004.GIF (50.65 KiB) Viewed 11130 times
- MW20003.GIF (49.86 KiB) Viewed 11130 times
- MW20000.GIF (28.59 KiB) Viewed 11131 times
Re: Summoner Cockpit?
It is a .WTB file acually. I was trying to get the galuzza mission working... pretty much have everything modded except one peice of code which netmech chokes on.
The ARE1 file for the galuzza mission is completely incompatible with netmech. The syntax is different let alone the references to in game objects. What was supposed to show up was a door, instead I got a cockpit laying on the ground.
You mean the "Mineshaft" Galuzza map?I was trying to get the galuzza mission working... pretty much have everything modded except one peice of code which netmech chokes on.
Yes. Basically the BWD must be reconstructed in order to get that map working.
I would not bother modeling it in mercs. If mech2 choked on GBL BWD's then it will do worse on that.
So you are saying that constructing for example, a TLBMESAM in Mercs won't build a TLBMESAM in 31cc? I knew that to be so with mechs and vehicles, but not scenery. I have a document that may help fix this problem, I'll get back with you on that later to see if I can help.
That reminds me, I tried to get a Falcon convoy escort mission to work on Mercnet, but EVERYTHING was wrong. The whole screen had an eriee green tint to it, the computer said I left the defined mission zone, I couldn't move, and I found out that the I.S.Battlesuit BWD refers to a convoy truck.
Or... if I can get a couple of good referance screenshots of the mineshaft mission from that gigantomous 100MB video, I can try to rebuild it too. Like you said once on chat, we can "race" to finish it.
