Just wanted to share a little something with those of you who play Xbox and MW2; you can play with an Xbox 360 controller!
Here's how-to:
1. Click here to get the drivers required to start. You will be asked a couple of questions about your OS to download the correct .dll files.
2. After you have downloaded the driver, plug-in your controller and go to your computer's control pannel, click "game controllers" and configure it whatever way. Hit "default settings/config" to make sure it is aligned correct.
3. It can take you forever to get the feel you want, so I have a pre-configured lay-out for download: . Download it over your existing input.map file in your Mechwarrior 2 directory.
4. Go to the configuration settings option on MW2, and hit "LOAD CUSTOM #1", the config should be named "Xbox 360". Accept the settings, and your done!
Let me know if you have any difficulties, I'll gladly help out!
Upon SPECIAL REQUEST, I might help out if you want to play using a Wii, or PS3 controller
