As the topic says I'm trying to start a career over after the last Luthien mission. I read this thread: viewtopic.php?t=294 however I'm having some difficulty getting mercs to do what I want. Basically I get the game to do one of 2 things. First thing that happens is after I've put CAMP as the first mission that I can access in the contract list, it allows me to choose the mission is slot 1 and run it but nothing happens after I abort the mission or abort from the dropship. It just keeps spitting the random missions at me after that. Second thing that happens is where I've changed the campaign type from 04 to 01 and done everything else exactly as previous, this time the game error's out when I open the contract list.
Technical specs are Win7 64-bit, Titanium version 1.1. Used MechVM to install but I'm running the game through windows compatibility mode for win 95 with "Run in 256 colors" and "Run in 640 x 480 resolution" checked. I've attached my .sav file as a txt in case anyone wants to look at what I did. Any help is appreciated!
Editing Savegame to start a campaign over
- mersave0.sav.txt
- (236.51 KiB) Downloaded 5258 times
