Mercs 1.1 Wininet.dll Installation Failed
Havokq3
Post by Havokq3 »
I have installed Mercs Win95 through MechVM on Windows 7 Pro SP1, and I am trying to patch to 1.1, but to no avail. When I run mpatch.exe and select 'Setup', then 'Continue>>', I receive an error message while it searches for the Mercs install directory. The message reads "WinINet.dll Redistribution Package: Installation Failed", and when I start the patched game, it lingers on a black screen before returning me to the desktop, with MechVM displaying "Process ended with 2ode 2" in the message window.
This is the error message.
wininet.dll ins fail.PNG (14.35 KiB) Viewed 55837 times
Havokq3
Re: Mercs 1.1 Wininet.dll Installation Failed
Post by Havokq3 »
That's strange; I installed Mercs on XP through Windows Virtual PC, but upon patching, I receive the same error message. :?:
Havokq3
Post by Havokq3 »
Case closed, the problem was that my disc already had v1.1 Windows, but the disc only says 1.05 on it. :roll:
Reece86
Post by Reece86 »
Can someone tell me where to install this patch to?
Do I install it through MechVM? And if so, how?
Thanks!
