A couple questions regarding install:
1.) On a new rig of mine running XP SP2, I follow the install steps but do not get very far. At step 6 the command prompt zooms to full screen and freezes, not the computer but it itself. The arrow keys are functionless and the clock in the upper-right stops. Is there anyway to stop this from happening?
2.)At the end of the installation instructions it says "First, you need these files and a .bat file, you may download them here."...Where??
3.) And I'm a bit confused at what I need to download. At the beginning of the instructions it says if its already installed just download the patch. At the end of step 22 it says download the patcher. Or if I choose to "continue reading" it describes "these files and a .bat file"
which of these do I need?
Mech 2 Install, Yes I've read the post on it
Re: Mech 2 Install, Yes I've read the post on it
Just use the patch, the other way is more difficult.
It will not harm your game even if you were using 1.1, it is a simple overwrite.
As for freezing, unfortuneatly i have never encountered it so I am unable to help.
I can give one of two suggestions.. when it goes full screen hit alt enter and it will go back to normal size if indeed it is not frozen.
Or just use dosbox.
Or just use dosbox.
