ok since we are entering a new era of 64bit
i have found a a way to get the battlemaster using a hex editor
To use the Battlemaster, you must first fix a bug, or your system will crash. Use a hex editor to make these changes:
•In file MW2.PRJ, change byte at offset 3206200 from 0x0B to 0x11,
and change byte at offset 3206752 from 0x0B to 0x11.
•In file MW2SHELL.EXE, search for string "btllmstr" and replace with "bttlmstr"
i found it on some site and i figured we could use it
hope this helps
Battlemaster fix without the 95 patch
- Demonslayer
