Game randomly stops working
John1780
Post by John1780 »
Have an issue with MechVM that has happened with two separate installs now. I'll install MechVM and it will work just fine for about a month, then it will suddenly stop working out of nowhere. When I start up MechVM, then click on GBL/MW2 and select 'start campaign,' it will begin loading as normal, entering the black full screen briefly, but then returns back to MechVM startup screen. I get a 'process ended with Code 0' on the command prompt in the background.
Would love to know how to fix this if there is a solution, other than reloading again each time, as I lose my campaign progress.
Thanks,
John
Re: Game randomly stops working
Please post your MechVM.cfg and relevant install-report.txt files for analysis.
