mechvm troubles
adams11
mechvm troubles
Post by adams11 »
having trouble getting game to work. i installed mechvm with no problems and installed mw2 mw2 gbl and mw2 mercs with no prob but when click play game and select game it flashes black then back to previous screen and i get a process ended with code -1073741819.. i have mw2 titanium trilogy winxp sp 3 pent dual core e6600 @3.06 ghz 3.5 gb ram amd radeon hd 6700 graphics
Re: mechvm troubles
Sorry, no idea why this would happen.
adams11
Re: mechvm troubles
Post by adams11 »
hope this helps
install-report.txt
(42.56 KiB) Downloaded 1024 times
Re: mechvm troubles
I have checked your install report. It does not significantly differ from mine, but my install works. Sorry, still no idea why it does not work for you. I have tried under WinXP and Win7, and both (mostly) work for me. If you can't get it to work, you may have to use either MechVM shell or a virtual machine like VMWare player.
