general info for titanium
Hi guys. where can i found all the tips to run titanium perfectly? It's possible to improve the graphics with a patch? I've an i7, nvidia 250 gts, 7 ultimate 64
Re: general info for titanium
graphics can't be improved.
Just use mechvm and you can get it installed easily or read the FAQ section.
MechVM installs Titanium with two tools that tweak its graphics, _farpatcher.exe and _titanRes3.exe. _farpatcher.exe adjusts the distance of the far clipping plane, meaning that this patch will let you look further into the distance. _titanRes3.exe allows you to run the game in additional resolutions, but there is a catch: you have to press F4 twice before targetting an enemy, or you have to abort the mission as the game screen is corrupted.
Also, you can tweak Titanium graphics by creating a profile for Titanium. In particular, experiment with the antialiasing settings.
However, we have not made a patch that adds higher resolution to the graphics in general. In my opinion, the most severe problem with Titanium is that the AI was dumbed down. While AI skill values for the AI can be slightly increased, I have not found a switch that will make enemies as aggressive as they were in the DOS version.
Thank you all! I tried to set farpatcher...but I don't know what i have to set! I've set 1204x768 in titanres3 but the screen is a rettangular on the top left and the aim ghost in the screen...my native res is 1920x1200.Skyfaller wrote:MechVM installs Titanium with two tools that tweak its graphics, _farpatcher.exe and _titanRes3.exe. _farpatcher.exe adjusts the distance of the far clipping plane, meaning that this patch will let you look further into the distance. _titanRes3.exe allows you to run the game in additional resolutions, but there is a catch: you have to press F4 twice before targetting an enemy, or you have to abort the mission as the game screen is corrupted.
What about gbl version? Is there any different?
As I said, and as you quote: you have to press F4 twice before targetting an enemy, or you have to abort the mission as the game screen is corrupted. Also, maybe you need 1280x768 rather than 1204x768. You can also try 1920x1200, but the screen may look distorted.
