Mission Failed
billysunday
Mission Failed
Post by billysunday »
I'm running Windows 7, 32 bit. I installed Mech Warrior 2: 31st Century Combat recently using this tutorial: http://www.youtube.com/watch?v=eCyNMEhTCtQ. I bought the game back in 1995. Everything works great until you choose to accept a mission. You immediately fail the mission and you are prompted to retry or abort the mission. Similarly, you can choose a tutorial mission, but you never actually get to run the tutorial. The screen just flickers and goes back to the tutorial select screen. Got any ideas?
Re: Mission Failed
The Pentium Editions currently run best in virtual machines like VMWare or Virtual PC.
Re: Mission Failed
I think it will only run on 32bit versions of Windows.. if you are running 64bit there probably is going to be more problems..
Your best bet is to buy a DOS version and use mechvm to install it and run it via dosbox.
