Resolution Fix Problem
chris0186
Post by chris0186 »
I've been having problems with MW2 and GBL DOS and tried to use the resolution fix. It says:
Installing the fix
Could not determine version of file C:\WINDOWS\system32\drivers\vga.sys
Please e-mail your file C:\WINDOWS\system32\drivers\vga.sys to shradecky@nomisso
ft.com for analysis and
perhaps inclusion into the patch list
Press any key to continue
Re: Resolution Fix Problem
What OS and Service Pack # are you using? If I recall correctly certain things only work on certain versions. Otherwise you might want to check out DOSBox.
chris0186
Post by chris0186 »
XP - Service Pack 2
It could be very well be that something else modified it.
Google says you are referring to this thread:
http://vogons.zetafleet.com/viewtopic.php?t=1659
"Windows 2000 SP3, Windows XP and Windows XP SP1"
You may need a new version of that file for XP SP2.
