Recreating the MW2 levels
I am making progress with recreating the MW2 levels. Next step is to get Mechs walking.
- Silent Thunder I
- MechVM 2020-02-28 20-41-57-48.png (84.76 KiB) Viewed 189786 times
- Silent Thunder II
- MechVM 2020-02-28 20-41-27-50.png (112.61 KiB) Viewed 189786 times
- Bouk Obelisk
- MechVM 2020-02-28 20-43-24-80.png (88.38 KiB) Viewed 189786 times
- Umber Wall
- MechVM 2020-02-28 20-44-39-72.png (73.71 KiB) Viewed 189786 times
- Rogue Chariot
- MechVM 2020-02-28 20-46-10-60.png (82.46 KiB) Viewed 189786 times
Re: Recreating the MW2 levels
Good stuff man!
Looks awesome!
How are you going about recreating the levels?
I have scripts that extract the levels, but the extraction does not fully work, so I have to adjust the object positions and colorize things. I recreate the skies by using screenshots as textures. One thing that helps a lot is taking screenshots from satellite view and putting them together to form a map, using GIMP. I've attached a map of Bouk Obelisk recreated from satellite view to demonstrate this.
I estimate that the Jade Falcon missions are about 80% complete. For the other campaigns, I only looked at a few levels to check that a similar process is going to work.
- map.png (46.4 KiB) Viewed 189715 times
Oh wow! How on earth did I miss all of this? Fantastic work man
Keep it up!!!
Awesome stuff! Is your code available somewhere? I'm a dev (though not usually in C/C++) and would love to see how you're doing this sorcery.
