MG_Man's Class Variants
User Submitted variants.
In this section you are only allowed to submit mechs you have built yourself. You must provide the specs for the mech.
MG_Man
Post by MG_Man »
I decided to show off a few of my successful class-based variants.
I will update this later with more that I make.
Class 1 (Lasers/PPC ONLY)
Mad Dog
MG/MDG-C1
This mech has nice heat efficiency and is quite fast. use best by grouping all the small lasers, then medium lasers, then large lasers together. Make sure the 3 are separate though.
Use the small/medium lasers to damage parts, then the large lasers to finish them off.
Also, this has jumpjets. (duh)
File name for this one is: MDG70USR.MEK
Marauder
MG/MDR-C1
This one is basically the same use as the Mad Dog, except it doesn't have small lasers. This one is better armored, however it's a bit slow. It has more jumpjets however.
Same usage applies.
File name: MRD70USR.MEK
Here's the RAR with the .MEKs. Put them in the MEK folder of Netmech/Mech2.
MGMEK.rar
Get the updated one here!
Fixes some armor issues.
(636 Bytes) Downloaded 6345 times
EDIT: Fixed the armor issues with both mechs.
