Tougher than anything
Initiative Phase for Round #7
WP-Odin rolls a 8.
Pepsi-Wolf rolls a 3.
WP-Cyril rolls a 12.
The turn order for movement is:
Pepsi-Wolf, WP-Odin, WP-Odin, WP-Odin, WP-Cyril, WP-Cyril
Wind direction is Northeast. Wind strength is Light.
WP-Cyril: 8761 BV remaining (from 14252 initially)
WP-Odin: 11959 BV remaining (from 14415 initially)
Pepsi-Wolf: 4438 BV remaining (from 14120 initially)
Movement Phase
Timber Wolf F (Pepsi-Wolf) must make a piloting skill check while moving in hex 1521 (running & turning on pavement).
Needs 3 [3 (Base piloting skill) + 0 (running & turning on pavement)], rolls 7 : succeeds.
Timber Wolf F (Pepsi-Wolf) must make a piloting skill check while moving from hex 1521 to hex 1520 (moved 3-4 hexes).
Needs 6 [3 (Base piloting skill) + 2 (moving through Heavy Building #28736) + 1 (moved 3-4 hexes)], rolls 10 : succeeds.
???? (????) must make a piloting skill check while moving in hex ???? (????).
Needs ???? [????], rolls ???? : succeeds.
???? (????) must make a piloting skill check (????).
Executioner F (WP-Cyril) must make a piloting skill check (getting up).
Needs 3 [3 (Base piloting skill) + 0 (getting up)], rolls 10 : succeeds.
Offboard Attack Phase
<nothing>
Weapon Attack Phase
Weapons fire for Timber Wolf F (Pepsi-Wolf)
ER PPC at Executioner F (WP-Cyril); needs 5, rolls 6 : hits LA
Executioner F (WP-Cyril) takes 15 damage to LA. Armor destroyed, 13 Internal Structure remaining
Critical hit on LA. Roll is 8; 1 location.
<<<CRITICAL HIT>>> on Double Heat Sink.
Ultra AC/20 at Executioner F (WP-Cyril); needs 5, rolls 8 : 2 shot(s) hit.
Executioner F (WP-Cyril) takes 20 damage to LA. <<<SECTION DESTROYED>>>,
7 damage transfers to LT.
Executioner F (WP-Cyril) takes 7 damage to LT. Armor destroyed,
Executioner F (WP-Cyril) takes 20 damage to LT. <<<SECTION DESTROYED>>>,
Executioner F (WP-Cyril) has taken 2 engine hits this round.
Checking for engine explosion on 12, roll is 5.
Engine safety systems remain in place.
Critical hit on LT. Roll is 12; 3 locations.
<<<CRITICAL HIT>>> on Engine.
<<<CRITICAL HIT>>> on +Medium Pulse Laser.
ER Medium Laser at Executioner F (WP-Cyril); needs 5, rolls 8 : hits LL
Executioner F (WP-Cyril) takes 7 damage to LL. 28 Armor remaining.
Weapons fire for ???? (????)
???? at ???? (????); needs ????, rolls ???? : hits ???? ????
???? (????) takes ???? damage to ????. Armor destroyed, ???? Internal Structure remaining
Critical hit on ????. Roll is ????; 1 location.
<<<CRITICAL HIT>>> on ????.
???? (????) takes ???? damage to ????. ???? Armor remaining.
???? (????) takes ???? damage to ????. ???? Internal Structure remaining
Critical hit on ????. Roll is ????; 2 locations.
Critical hit on ????. Roll is ????; no effect.
???? at ???? (????); needs ????, rolls ???? : fails to achieve lock.
???? at ???? (????); needs ????, rolls ???? : ????????hit????.
???? (????) has taken ???? engine hits this round.
Checking for engine explosion on ????, roll is ????.
Critical hit on ????. Roll is ????;<<<LIMB BLOWN OFF>>> ???? blown off.
Weapons fire for Executioner F (WP-Cyril)
Streak SRM 6 at Timber Wolf F (Pepsi-Wolf); needs 5, rolls 7 : 6 missile(s) hit.
Building #28736 absorbs 2 points of damage.
Timber Wolf F (Pepsi-Wolf) suffers no damage.
Medium Pulse Laser at Timber Wolf F (Pepsi-Wolf); needs 3, rolls 4 : hits RT
Building #28736 absorbs 7 points of damage.
Medium Pulse Laser at Timber Wolf F (Pepsi-Wolf); needs 3, rolls 8 : hits RT
Medium Pulse Laser at Timber Wolf F (Pepsi-Wolf); needs 3, rolls 7 : hits LT
Medium Pulse Laser at Timber Wolf F (Pepsi-Wolf); needs 3, rolls 7 : hits LL
Medium Pulse Laser at Timber Wolf F (Pepsi-Wolf); needs 3, rolls 7 : hits CT
Medium Pulse Laser at Timber Wolf F (Pepsi-Wolf); needs 3, rolls 7 : hits RA
Medium Pulse Laser at Timber Wolf F (Pepsi-Wolf); needs 3, rolls 3 : hits LA
???? at ???? (????); needs ????, rolls ???? : misses.
???? at ???? (????); needs ????, rolls ???? : hits with ???? inferno missles.
Target gains ???? more heat during heat phase.
???? (????) must make ???? piloting skill roll(s) (????).
The base target is ???? [????].
Roll #????, (????); needs ????, rolls ???? : falls.
???? (????) falls on its ????, suffering ???? damage.
Pilot of ???? (????) "????" must roll ???? to avoid damage; rolls ???? : succeeds.
Executioner F (WP-Cyril) must make 1 piloting skill roll(s) (62 damage +3, weight class modifier -2).
The base target is 3 [3 (Base piloting skill)].
Roll #1, (62 damage +3, weight class modifier -2); needs 4, rolls 8 : succeeds.
???? (????) must make ???? piloting skill roll(s) and automatically fails (????).
*** ???? EXPLODES! ???? DAMAGE! ***
???? (????) takes ???? damage to ????. <<<SECTION DESTROYED>>>,<<<LIMB BLOWN OFF>>> ???? blown off.
*** ???? (????) DESTROYED by ????! ***
remaining ???? damage prevented by CASE.
Pilot of ???? (????) "????" takes ???? damage.
Physical Attack Phase
<nothing>
Heat Phase
Summoner I ID:4 (WP-Odin) gains 2 heat, sinks 2 heat and is now at 0 heat.
???? (????) gains ???? heat, sinks ???? heat and is now at ???? heat.
Adding 5 heat from a fire...
???? (????) needs a ????+ to avoid shutdown, rolls ???? : shuts down.
???? (????) needs a ????+ to avoid ammo explosion, rolls ???? : avoids successfully!
Executioner F (WP-Cyril) gains 56 heat, sinks 32 heat and is now at 24 heat.
Executioner F (WP-Cyril) needs a 8+ to avoid shutdown, rolls 7 : shuts down.
Executioner F (WP-Cyril) must make 1 piloting skill roll(s) (reactor shutdown).
The base target is 6 [3 (Base piloting skill) + 3 (reactor shutdown)].
Roll #1, (reactor shutdown); needs 6, rolls 7 : succeeds.
Executioner F (WP-Cyril) needs a 6+ to avoid ammo explosion, rolls 4 : fails to avoid explosion.
Luckily, there is no ammo to explode.
Timber Wolf F (Pepsi-Wolf) gains 36 heat, sinks 37 heat and is now at 0 heat.
End Phase
Light smoke fills 1015.
Light smoke fills 1610.
Light smoke fills 1807.
Light smoke continues to fill 1907.
Light smoke fills 1912.
Heavy smoke overpowers light smoke in 2106.
Light smoke fills 2604.
Buildings
- Pepsi-Wolf
- House Steiner Hauptmann
Buildings
- Pepsi-Wolf
Re: Buildings
04/17/08
Weapon Attack Phase
Weapons fire for Bane Bane 4 (WP-Cyril)
Ultra AC/20 at Nova Cat MC-A (Pepsi-Wolf); needs 7, rolls 6 : misses.
Ultra AC/20 at Nova Cat MC-A (Pepsi-Wolf); needs 7, rolls 9 : 1 shot(s) hit (using Partial cover table).
Nova Cat MC-A (Pepsi-Wolf) suffers no damage.(LL behind cover)
Weapons fire for Blood Asp B (Pepsi-Wolf)
Gauss Rifle at Hex 2124 of Building #47184 (Collapse); needs 2, rolls 6 : hits.
Building #47184 absorbs 15 points of damage.
LRM 20 at Hex 2124 of Building #47184 (Collapse); needs 2, rolls 7 : 16 swarm-I missile(s) hit (using Partial cover table).
Building #47184 absorbs 16 points of damage.
LRM 20 at Hex 2124 of Building #47184 (Collapse); needs 2, rolls 6 : 9 swarm-I missile(s) hit (using Partial cover table).
Building #47184 absorbs 9 points of damage.
Medium Pulse Laser at Hex 2124 of Building #47184 (Collapse); needs 0, rolls 6 : hits.
Building #47184 absorbs 7 points of damage.
Medium Pulse Laser at Hex 2124 of Building #47184 (Collapse); needs 0, rolls 4 : hits.
Weapons fire for Burrock BRK (WP-Cyril)
Ultra AC/20 at Timber Wolf Hydra (Pepsi-Wolf); needs 4, rolls 7 : 1 shot(s) hit.
Building #47184 absorbs 11 points of damage.
Timber Wolf Hydra (Pepsi-Wolf) takes 9 damage to LA. 15 Armor remaining.
Heavy Medium Laser at Timber Wolf Hydra (Pepsi-Wolf); needs 5, rolls 10 : hits RA
Building #47184 absorbs 10 points of damage.
Timber Wolf Hydra (Pepsi-Wolf) suffers no damage.
Heavy Medium Laser at Timber Wolf Hydra (Pepsi-Wolf); needs 5, rolls 2 : misses.
Heavy Medium Laser at Timber Wolf Hydra (Pepsi-Wolf); needs 5, rolls 5 : hits LA
Weapons fire for Komodo IIC KIM-IIC (WP-Cyril)
Medium Pulse Laser at Nova Cat MC-A (Pepsi-Wolf); needs 4, rolls 7 : hits (using Right Side table) RT
Nova Cat MC-A (Pepsi-Wolf) takes 8 damage to RT. 15 Armor remaining.
Medium Pulse Laser at Nova Cat MC-A (Pepsi-Wolf); needs 4, rolls 4 : hits (using Right Side table) LT
Nova Cat MC-A (Pepsi-Wolf) takes 8 damage to LT. 15 Armor remaining.
Medium Pulse Laser at Nova Cat MC-A (Pepsi-Wolf); needs 4, rolls 7 : hits (using Right Side table) RL (critical)
Nova Cat MC-A (Pepsi-Wolf) takes 8 damage to RL (critical). 20 Armor remaining.
Critical hit on RL. Roll is 8; 1 location.
<<<CRITICAL HIT>>> on Upper Leg.
Medium Pulse Laser at Nova Cat MC-A (Pepsi-Wolf); needs 4, rolls 3 : misses.
Nova Cat MC-A (Pepsi-Wolf) takes 8 damage to RT. 7 Armor remaining.
Medium Pulse Laser at Nova Cat MC-A (Pepsi-Wolf); needs 4, rolls 7 : hits (using Right Side table) LT
Nova Cat MC-A (Pepsi-Wolf) takes 8 damage to LT. 7 Armor remaining.
Nova Cat MC-A (Pepsi-Wolf) takes 8 damage to RT. Armor destroyed, 14 Internal Structure remaining
Critical hit on RT. Roll is 5; no effect.
Medium Pulse Laser at Nova Cat MC-A (Pepsi-Wolf); needs 4, rolls 4 : hits (using Right Side table) RT
Nova Cat MC-A (Pepsi-Wolf) takes 8 damage to RT. 6 Internal Structure remaining
Critical hit on RT. Roll is 6; no effect.
Medium Pulse Laser at Nova Cat MC-A (Pepsi-Wolf); needs 4, rolls 9 : hits (using Right Side table) RA
Nova Cat MC-A (Pepsi-Wolf) takes 8 damage to RA. 13 Armor remaining.
Medium Pulse Laser at Nova Cat MC-A (Pepsi-Wolf); needs 4, rolls 6 : hits (using Right Side table) RT
Nova Cat MC-A (Pepsi-Wolf) takes 8 damage to RT. <<<SECTION DESTROYED>>>,<<<LIMB BLOWN OFF>>> Right Arm blown off.
Nova Cat MC-A (Pepsi-Wolf) has taken 2 engine hits this round.
Checking for engine explosion on 12, roll is 7.
2 damage transfers to CT.
Critical hit on RT. Roll is 7; no effect.
Nova Cat MC-A (Pepsi-Wolf) takes 2 damage to CT. 31 Armor remaining.
Weapons fire for Night Gyr Prime (Pepsi-Wolf)
ER PPC at Burrock BRK (WP-Cyril); needs 8, rolls 3 : misses.
Building #47184 absorbs 15 points of damage. <<<BUILDING DESTROYED>>>
Ultra AC/10 at Burrock BRK (WP-Cyril); needs 8, rolls 11 : 1 shot(s) hit (using Partial cover table).
Burrock BRK (WP-Cyril) suffers no damage.(RA behind cover)
Medium Pulse Laser at Burrock BRK (WP-Cyril); needs 8, rolls 6 : misses.
Medium Pulse Laser at Burrock BRK (WP-Cyril); needs 8, rolls 7 : misses.
Weapons fire for Nova Cat MC-A (Pepsi-Wolf)
Medium Pulse Laser at Burrock BRK (WP-Cyril); needs 3, rolls 6 : hits (using Rear table) LA
Building #47184 absorbs 8 points of damage.
Medium Pulse Laser at Burrock BRK (WP-Cyril); needs 3, rolls 7 : hits (using Rear table) LL
Medium Pulse Laser at Burrock BRK (WP-Cyril); needs 3, rolls 10 : hits (using Rear table) LA
LB 20-X AC at Burrock BRK (WP-Cyril); needs 4, rolls 7 : 16 shot(s) hit (using Rear table).
Building #47184 absorbs 1 points of damage.
LB 20-X AC at Burrock BRK (WP-Cyril); needs 4, rolls 3 : misses.
Building #47184 absorbs 6 points of damage.
Weapons fire for Ryoken II Tassa (WP-Cyril)
ER PPC at Nova Cat MC-A (Pepsi-Wolf); needs 6, rolls 8 : hits LA
Nova Cat MC-A (Pepsi-Wolf) takes 15 damage to LA. 6 Armor remaining.
ER PPC at Nova Cat MC-A (Pepsi-Wolf); needs 6, rolls 8 : hits LT
Nova Cat MC-A (Pepsi-Wolf) takes 15 damage to LT. Armor destroyed, 7 Internal Structure remaining
Critical hit on LT. Roll is 6; no effect.
Weapons fire for Timber Wolf Hydra (Pepsi-Wolf)
ER Medium Laser at Bane Bane 4 (WP-Cyril); needs 4, rolls 4 : hits RL
Bane Bane 4 (WP-Cyril) suffers no damage.
Streak SRM 4 at Bane Bane 4 (WP-Cyril); needs 4, rolls 7 : 4 missile(s) hit.
Building #47184 absorbs 2 points of damage.
Streak SRM 4 at Bane Bane 4 (WP-Cyril); needs 4, rolls 6 : 4 missile(s) hit.
Streak SRM 4 at Bane Bane 4 (WP-Cyril); needs 4, rolls 2 : fails to achieve lock.
LB 10-X AC at Bane Bane 4 (WP-Cyril); needs 3, rolls 7 : 4 shot(s) hit.
LB 10-X AC at Bane Bane 4 (WP-Cyril); needs 3, rolls 8 : 6 shot(s) hit.
ER Small Laser at Bane Bane 4 (WP-Cyril); needs 6, rolls 8 : hits RA
Building #47184 absorbs 5 points of damage.
Building #47184 collapses due to damage.
Timber Wolf Hydra (Pepsi-Wolf) is hit by falling debris for 44 damage.
Timber Wolf Hydra (Pepsi-Wolf) takes 5 damage to LA. 10 Armor remaining.
Timber Wolf Hydra (Pepsi-Wolf) takes 5 damage to CT. 31 Armor remaining.
Timber Wolf Hydra (Pepsi-Wolf) takes 5 damage to LT. 20 Armor remaining.
Timber Wolf Hydra (Pepsi-Wolf) takes 5 damage to RA. 19 Armor remaining.
Timber Wolf Hydra (Pepsi-Wolf) takes 5 damage to RT. 20 Armor remaining.
Timber Wolf Hydra (Pepsi-Wolf) takes 5 damage to RL. 27 Armor remaining.
Timber Wolf Hydra (Pepsi-Wolf) takes 5 damage to RT. 15 Armor remaining.
Timber Wolf Hydra (Pepsi-Wolf) takes 5 damage to RL. 22 Armor remaining.
Timber Wolf Hydra (Pepsi-Wolf) takes 4 damage to LT. 16 Armor remaining.
Burrock BRK (WP-Cyril) is hit by falling debris for 44 damage.
Burrock BRK (WP-Cyril) takes 5 damage to RL. 23 Armor remaining.
Burrock BRK (WP-Cyril) takes 5 damage to LL. 23 Armor remaining.
Burrock BRK (WP-Cyril) takes 5 damage to CT. 23 Armor remaining.
Burrock BRK (WP-Cyril) takes 5 damage to HD. 4 Armor remaining.
Pilot of Burrock BRK (WP-Cyril) "Legion" takes 1 damage.
Burrock BRK (WP-Cyril) takes 5 damage to LT. 16 Armor remaining.
Burrock BRK (WP-Cyril) takes 5 damage to LT. 11 Armor remaining.
Burrock BRK (WP-Cyril) takes 5 damage to LA. 16 Armor remaining.
Burrock BRK (WP-Cyril) takes 5 damage to RA. 16 Armor remaining.
Burrock BRK (WP-Cyril) takes 4 damage to LA. 12 Armor remaining.
Bane Bane 4 (WP-Cyril) is hit by falling debris for 44 damage.
Bane Bane 4 (WP-Cyril) takes 5 damage to RA. 29 Armor remaining.
Bane Bane 4 (WP-Cyril) takes 5 damage to CT. 41 Armor remaining.
Bane Bane 4 (WP-Cyril) takes 5 damage to RT. 27 Armor remaining.
Bane Bane 4 (WP-Cyril) takes 5 damage to LL. 37 Armor remaining.
Bane Bane 4 (WP-Cyril) takes 5 damage to LT. 27 Armor remaining.
Bane Bane 4 (WP-Cyril) takes 5 damage to RA. 24 Armor remaining.
Bane Bane 4 (WP-Cyril) takes 5 damage to LL. 32 Armor remaining.
Bane Bane 4 (WP-Cyril) takes 5 damage to CT. 36 Armor remaining.
Bane Bane 4 (WP-Cyril) takes 4 damage to RA. 20 Armor remaining.
Pilot of Burrock BRK (WP-Cyril) "Legion" needs a 3 to stay conscious. Rolls 6 : successful!
Timber Wolf Hydra (Pepsi-Wolf) must make 1 piloting skill roll(s) (53 damage +2, weight class modifier -1).
Roll #1, (53 damage +2, weight class modifier -1); needs 4, rolls 12 : succeeds.
Nova Cat MC-A (Pepsi-Wolf) must make 2 piloting skill roll(s) (leg/foot actuator hit; 102 damage +5, weight class modifier -1).
The base target is 4 [3 (Base piloting skill) + 1 (leg/foot actuator hit)].
Roll #1, (leg/foot actuator hit); needs 4, rolls 9 : succeeds.
Roll #2, (102 damage +5, weight class modifier -1); needs 8, rolls 9 : succeeds.
Bane Bane 4 (WP-Cyril) must make 1 piloting skill roll(s) (44 damage +2, weight class modifier -2).
Roll #1, (44 damage +2, weight class modifier -2); needs 3, rolls 7 : succeeds.
Burrock BRK (WP-Cyril) must make 1 piloting skill roll(s) (44 damage +2, weight class modifier -1).
Roll #1, (44 damage +2, weight class modifier -1); needs 4, rolls 8 : succeeds.
Weapon Attack Phase
- buildings.jpg (306.85 KiB) Viewed 51030 times
