Installed on Vista with DOSBOX, still issues[screenshots]
Re: Installed on Vista with DOSBOX, still issues[screenshots]
Did you make sure that Mercs was set to 98?
Also the target path should look something like this
"C:\Program Files\MW2Hook\MW2Inject.exe" "H:\MW2Titanium\Mw2win.exe"
An example (tho not great) can be seen here.
