I dusted off my old box to install Win98SE, took me all morning. Installing Mercs and patching to 1.1 went easy, it even asks whether you want to install improved 3D graphics. But I didn't get it to run, not on the Win98SE box, nor under Vista after manually patching to the *42.dll's combined with the hook. It says "DP DLL ERROR - BUG - Negative Threads".
Update: It worked in Vista32, no mw2inject.exe needed, though still unstable. It automatically used my desktop resolution and targetting worked. That means, it may be better than Titanium Mercs in this regard - the resolution patches for Titanium require targetting to be disabled, if you recall.
minor issues
Re: minor issues
- mw2-mercs-win-1.1-Bild 2.png (427.88 KiB) Viewed 10010 times
Re: minor issues
It seems a patch to Mercs 1.1 was published in this thread:
viewtopic.php?f=17&t=514
Re: minor issues
Prob is tho with that guide is that requires a WAV folder which does not exist on most versions of mercs.
- Jerad Gray
- House Steiner Private
Re: minor issues
-Sir MMPD Radick
-StrangeMetal
That started long before I had to go to running merc on 7/vista, it just seems to be caused by the newer tech in a person's computer.
GFX - NVIDIA GeForce 9600 GT
CPU - Intel(R) Core(TM)2 Duo CPU E7400 @ 2.8GHz
SND - Creative SB X-Fi (PCI Card)
Perhaps someone could upload it then...Prob is tho with that guide is that requires a WAV folder which does not exist on most versions of mercs.
-StrangeMetal
Yeah thats a fun one, I should see if alt tabbing fixes it next time, although I think I remember that it doesn't.- After a mission, the interface palette glitches and debriefing screen is totally black
fix: click on the menu at the top to go to Combat Variables screen then right click out of the Combat Var. screen to go back into the fixed debrief screen
fix: click on the menu at the top to go to Combat Variables screen then right click out of the Combat Var. screen to go back into the fixed debrief screenNever saw this happen either.- During the sim, parts of the world flicker in and out of visibility even though they are in range
no fix? I applied the visible range patch to 1600 meters, but it didn't glitch like that before in v1.05...
I have yet to see any texture related lag.- INCREDIBLE lag when you turn on ANY texturing (or even when you see it, even though it's off)
no fix: for the DC missions where you have to venture into a city to destroy the third floor office, the buildings are textured whether you have it on or off and if you approach the city the lag becomes so intense that the sim turns into a slideshow... this should NOT happen on a PC that was made a full 10 years after the game's been released...
Never occurs for me.- Momentary lag when dynamic lights appear; firing of any weapon, there's a lag when the dynamic light is rendered...
no fix.
I may have notced this once before, but it happened a long time ago if I did.- Game crashes randomly when receiving a radio message...
fix: re-run the game, it sometimes goes through and doesn't crash
