Can someone please help?
Re: Can someone please help?
i'm sorry i missed you i went off the bed by 12 AM.
I am on PST.. i'll be on probably till 10-11 PM tonight
Captianwaffles
Post by Captianwaffles »
Ah thank you anyway, Madsonovich helped me install it useing dosbox and clonce cd wothout the mech vm. We got it running but I can't seem to run the .exe file with DOSBOX. WHat do I type in DOSBOX (after mounting the drive) to get it to run?
It depends on how you set it up... It varies.
say you are in C: then you need to go to the mechwarrior 2 dir...
You would type "cd Mech2" if it is not named that then you need to get the directory from C: so type dir.
Now if you are not in C: type C: to get to the C: drive.
Once you are in the directory type Mech2
