Adjusting screen for mechwarrior 2
- Demonslayer
Re: Adjusting screen for mechwarrior 2
nope no luck
I may have seen this error before, but it was possible to fix it by task switching. If that doesn't work, MechVM shell may help. It tries to emulate the 2D parts of MW2, aside from the sim itself. MechVM shell does not have music, sound or animations, but can be used to launch the sim, and it displays the background images of the original shell. I would have to do some tests and offer a version of MechVM that supports this.
Or you could try running the game in a virtual machine, Virtual PC or VMWare player.
- Demonslayer
well the screen did not even work for the ingame but it worked for the shells screen and please make a platnium (bp graphics) mechvmshell.
matter of fact i found a ingame picture taker ill give u a pic soon of the gameplay and etc
- Demonslayer
nvm it wont work
May I suggest you use a physical camera to take the screenshot? It would help everyone document the issue.
